Check Engine Light CEL error 41 help
bosch will sell a OEM replacement and a Universal replacement,..the OEM replacement is of course going to be expensive (somewhere in the $200 range) and the Universal replacement will be around 80 bucks,..the OEM replacement will plug right up with no splicing,..the Universal replacement will have to be spliced but they supply you with a connector that makes everything look clean
I have used the bosch one that's cheapo, the splicing the wire one. It seemed to work but I don't like it. I remember taking advanced engine performance classes they were saying that the OEM o2 sensors are calibrated from the factory to work with the OEM computer. If you repair a wire in the o2 sensor wiring(or in this case just splice one in)
the wiring gets increased resistance from the added splice which alters the signal. The signal is usually like 0-5 volts and switches when you going down the road, well if you add some resistance to the wiring that is not suppose to be there the computer will get a signal that is lower than normal. I personally would not put one on my hondas.
However the customer wanted a bosch one installed that spliced in so i put it in no warrenty... It seems to switch and work okay but i don't trust it. Just a thought though to think about.
Well to do that you would have to butt connect it correct? that's extra resistance...
I have this same thing with mine, but I have not been able to figure it out.... Can anyone do me a favor and take a picture or tell me the wiring placement for these wires from the O2 Sensor to the the splices? We went by a OBDI 95 Civic, and I think that they are in different places than the OBDII 99 that I have. We have tried everything, and now, I just don't think that the wires are in the right place....
I see where you are going but would you trust that as an acceptable repair??? I would just buy the right part and suck it up.
