help, big problem!!
Old May 9, 2004 | 08:25 AM
vtecadil's Avatar
vtecadil
Default help, big problem!!
alright got my rims and tires put on, but now when i turn right it rubs! on the left front, i think its hitting this little hump in the wheel well, but im only lowered on tein s-techs and AGX's im not slammed so i cant figure out why im rubbing, and its only on that one side. i bought 3mm wheel spacers, does anyone think that will help??? oh and it like rubbed when i went over a dip goin like 45 not a big one but just one that ull encounter with daily driving.
Old May 9, 2004 | 08:37 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
roll the fender walls with a bat. If that dosnt help that then maybe try the spacer.
Old May 9, 2004 | 09:01 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
what size tires are you running?
Old May 9, 2004 | 09:08 AM
vtecadil's Avatar
vtecadil
Old May 9, 2004 | 09:46 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
What offset are the wheels?
Old May 9, 2004 | 10:11 AM
vtecadil's Avatar
vtecadil
16X7 rota C8's
Old May 9, 2004 | 10:56 AM
vtecadil's Avatar
vtecadil
does anyone have any suggestions?
Old May 9, 2004 | 03:50 PM
randomtask77's Avatar
randomtask77
Wanderer
How's your alignment? More specifically your camber.
I have a set of 16x7" wheels with a +37mm offset mated with 205/45/16 and not really lowered much (about a finger gap between the tire and the fender). I don't experience rubbing when the steering wheel is turned all the way on either side, but I experience rubbing while I'm driving and hit minor bumps/holes or if I'm going pretty fast on a turn.
Also, what kind of tires are you running? Sometimes tire manufacturers have different dimensions and some have bigger sidewalls than others.
Old May 9, 2004 | 04:34 PM
importkustoms00's Avatar
importkustoms00
Korean DOOD
same here but i have 17's and the H&R sport springs
Old May 9, 2004 | 05:20 PM
vtecadil's Avatar
vtecadil
toyo proxes FZ4's and i had an alignment, but maybe i should get another one. and i have a two finger gap all around. im gonna put the spacers on tomm and see what happens.
