cluster and heater control lights are out...
Old May 18, 2004 | 07:53 PM
sspire's Avatar
sspire
Default cluster and heater control lights are out...
just noticed when i got out of work. i looked for a fuse but didnt see anything i also dont have a nice little diagram of what the fuses are. i took my consol and head unit out this afternoon, would anything down there affect my cluster/heater control lights? right now im up for and ideas, a diagram would be helpful.
Old May 18, 2004 | 10:22 PM
randomtask77's Avatar
randomtask77
Wanderer
Might want to check the one for the radio. If not, then check the fuses that are under the hood (near the battery).
Old May 18, 2004 | 10:51 PM
Nelson's Avatar
Nelson
Administrator
The dimmer switch may be faulty as well.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 20, 2004 | 09:26 AM
sspire's Avatar
sspire
update tail lights are out too brake lights work but tail lights dont
Old May 20, 2004 | 10:17 AM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
Check all of your fuses.
For some reason when a certain one goes out then all the rest start acting up. Youlle find them under your hood and near the kick panel of the drivers side
Old May 20, 2004 | 06:37 PM
KeepinOnThaDL's Avatar
KeepinOnThaDL
sorry to jack thread but... the left side of my heater\ac control light is out, but right is still on. is it just a bulb? and what would I need to get?
Old May 21, 2004 | 12:57 AM
ReVenGe's Avatar
ReVenGe
heh..... emphasis on dimmer switch..... i did a custom gauge install, and when i put everything back in, i forgot to connect the plug into the dimmer, so its default would be off...... had about 3 brain anurisms before i realized it.....
(side note, are the sliding tabs for the heat and fan level supose to have lights on them? cause looks like its supose to light up maybe green, but mine dont, everything else is ok)
Old May 21, 2004 | 11:38 AM
dantastic's Avatar
dantastic
cx power!
sounds like your entire parking light (one click on the headlight switch) is out. since you removed the conole and radio, you may have pinched or shorted a parking light wire (there's one that goes to the radio, one to the ashtray). check the parking light fuse 1st. if the dimmer switch was the culprit only your cluster and hvac lights would be out
