any type of malfunction in the air bag system will set off that light. I would perhaps go get the airbag checked out if you care enough to pay for it. I think since the light is on your SRS is disabled and if you got in a wreak your airbag wouldn't go off. If you don't mind not having an airbag just take the lightbulb outta your gauge cluster and problem is solved
any instructions on how to remove that bulb, i have the same light staying on since i changed to an sir cluster?
the same way you put that cluster in.. you just have to pull it back out... and then find out which blub, twist the blub and pull out. Its a very easy process
