brake problem
Old May 5, 2004 | 01:24 PM
jordan88's Avatar
jordan88
Default brake problem
hi, i have a 97 civic lx sedan d16y7. what usually cause the brakes vibrates, when i step on the brakes, the brake padel vibrates and also the steering wheel as well.
Another question is, when i check my engine oil after the car had been running for about 30mins, the oil is like low, but i just had an oil change not very long as ago.
thx
Old May 5, 2004 | 01:46 PM
shivers's Avatar
shivers
Moderator Alumni
1. Your rotors are "warped" ... actually it's material transfer from the pads. You can have them turned at a shop that does brake work or you can get new ones. You should probably check the condition of the brake pads and replace those as well.
2. When an engine is running, the oil is circulating through it to lubricate all of the moving parts. Since the oil is displaced from movement, the dipstick will read low if you check the oil immediately after shutting off the car. Let the car sit for a while and all of the oil will return to the oil pan and give you the correct reading.
2005 s2000
TegraGSR
Mar 1, 2004 05:45 PM
white_n_slow
92+ Civic/EL & Del Sol
5
Aug 14, 2003 02:00 PM
theguy386
3
Aug 13, 2003 09:47 AM
keefungliu
Mar 21, 2003 05:30 AM
bokchoyboi
3
Oct 21, 2002 08:18 PM
