- mini-me done.. finally..
- turbo
- OBD1 and OBD2 questions
- swap B20b into a 93 civic
- Is Installing Tranny Hard
- Trouble Code 9? (cyp)
- Head light painting 7th Gen.
- Where to buy Tranny
- civic takes a poopy now what motor to put in
- b16
- Ecu issue
- Car odb! Check engine light!! Help (Already checked other posts)
- Online Resources Thread - Updated 7/04/2006
- K20 in civic¿?¿?¿?¿
- 96 civic interior question
- 96-98 B18C1 Info For Build
- Ls Swap Questions
- Need Help!!! Honda Civic 4Dr '92
- projector headlights
- What would I need to datalog?
- Cylinder Head swap help
- 97 Civic LX- What TB's will work?
- Replacing screws after changing rotors?
- Best wheels for a Del Sol
- integra door panels
- Cruise Control in 92-95 JDM EG or EJ Civic
- S2000 OEM Steering Wheel in a Civic???
- Ingalls Engine Torque Damper Review/Install
- Show Me How To Hook Up Boost Controller
- Whatsup guys
- sir2 performance
- Starter Relay Location??
- Honda civic EX 99 Turbo ???????
- I need pic of the inside of
- H22 VS. H23 swap into the sol
- Ls Help
- M3-g2 Power Mirror W/led......
- Basic AC help
- how to remove a 2000 civic si factory stereo
- jdm b16a into a 93 del sol s
- Pictures of my Em1.
- help before i really screw something up
- civic D15b2
- civic water problem
- Arkansas and B16A's
- front end noise
- turbo k20?
- ecu
- Transmission compatability?
- Civic XM Radio ready recommendations?
- Wastegate NOT Opening/ Vacuum Problem?
- 97 Civic A/C
- sir2 performance
- civic springs
- civic engine conversion
- ex exhaust
- Whats up with this??
- a/c evaporator core
- h22 in eg.se
- what do i need
- b16a
- Repairing Rear Body Panels
- Multiple Questions
- New Sized Wheels (need opinion or expertise)
- Jdm Ecu..
- vtec disappeared?
- 1995 Civic Wont Fire
- check engine light
- car sways side to side with 3 or more people inside why??
- Sohc Vtec Knock Sensor: Needed Or Not?
- civic sir2 cluster
- searched: 97 integra brakes on my 98 hb
- Pinstripe Removal on 98 Civic
- EG lips from JDMcarboy???
- ls/vtec vs. GSR
- nm
- hydrolics.... :( ? need help asap
- Hit ans Run!!!! Pic inside.
- damn civic
- I Need a Honda Civic Carpet!
- 93 Civic Clutch Problems
- Rear Lip?
- I am New got a few questions
- enigeine size d13b2
- oh yeah
- slow and funny
- Buying a CTR front clip with everything
- civic SIR2
- Everyone Please Help Turbo??
- rear disc ek question
- Clutch Problems
- which ecu is better?
- Funny brake issue
- Cx hatch
- Tan interior
- Need Some D.. Info
- Bye bye 00 Civic Si.... I will miss you.
- Car doesnt Start after it runs
- Attn: Anybody who has bought Brembo blank rotors for their civic...
- Windshield Length
- CO2 sprayer
- Runing Rich???
- Prove It...
- Brake Design
- Final Plan (due to funding restrictions)
- Timing Gears ...
- Turbo Kits on Ebay
- Help With Tach
- So it's bad to autocross like this, right?
- Replacing VSS
- Deciding To Buy a 93' Honda Civic
- Deciding On A Honda
- Looking for Black 10 Spoke Rims
- water pump
- Turbo Downpipe Installation Problem
- 96 Del Sol Mugen kit
- Mirror Trouble
- 94 civic lx STARTING PROJECT?
- 1991 Civic DX 4DR main relay
- rods
- Rear disc parts.
- b18b swap questions
- car stalls, then doesn't start/no spark
- Need help with code 22
- p08...
- Need Help!!!
- Help Asap
- 95 civic rpm gauge
- JDM OBD2 ecu vehicle inspection issues.
- Trunk sensor trouble
- integra swap
- compression 411 / engine paint / d16
- Header questions
- H22a into 00' Si, I can't figure some stuff out!
- It has begun...
- Where to buy a....................
- Tha Mod Is Done! Pix!
- Tires Squealing
- auto swap question
- Suspension help needed
- JDM?? everything
- 94 teggy dash in a 95 civic?
- Weight reduction for my DEL SOL SI
- Just a quick question
- need help
- My 2006 setup FINALLY bout done! Tons of PIX
- Estimate the damage.
- Monk-E's Car =]
- B16A1 swap into 96 Civic HB - Confirmation questions before buying
- b16a2 swap, half of del sol cluster not working
- Best repair manual?
- flanged??
- ????1995 honda civic?????HELP!
- cam timing
- new headers and cat
- front pulley clicks
- Right sie inner tierod?
- Good Buy???
- KYB AGX + H&R Sports
- F20C(S2000) In EK/EG
- harness
- looking for suggestions on a clutch
- how do you do it.
- gsr
- d15b7 intake manifold on D16y7 ??
- new exhaust
- auto windows
- 95 honda civic revving
- B16 engine head cover colors
- msd ignition help jdm b16
- Fuel injector check?
- interchangeable sunroof
- 94 civic hatch help!!
- del sol front speaker size?
- 2002 Acura EL
- Locating a tranny.
- obd1 conversion..
- DPFI-MPFI-OBD0-OBD1 conversion
- Trouble with shaving
- New Project, sort of
- Tire Rubbing Wheel Well..please Help
- rods
- 1994 coupe to 2000 coupe
- having some problems now that im boostin
- Exhaust Pipe
- Radiator Upgrade question
- What's the best?
- OXIDATION on rims?
- Is there such thing as "JDM Fogs"?
- Power Lock Kits??
- dust boot
- It's ALiVE!!!
- Launch RPM for gsr turbo
- Don't know how much more i can take...car woes :(
- Swap requirements help!!!!!!
- High Rev Engine Options (If you're sick of these.. don't read it!)
- Reeeally quick OEM hood question
- Anyone dealt with these guys?
- min. compression tales?
- Burned out Del Sol headlight relay I think - where is it??
- Is this a good deal? reply asap
- throttle Cable Problems
- Battery Suggestions
- 99-00 fog lights bulb remove and install...
- k 20 swap stuff
- msd ignition help
- 05 Civic ex steering wheel badge
- manual window..
- spark plugs
- Is my radiator shot?
- Gas Guage Broken~!!
- over heating problem
- say goodbye to civic and hello to rotary power
- OIl Pressure switch
- y7 into a 92 cx
- pioneer DEh-p6700mp wiring help!!!!
- what gaskets
- brights and drls on at same time???
- what clutch to buy
- High Boost and Torque, without NO2
- 96 honda v-tech head on a d16
- halo projector light with angle eyes for 03 accord
- side molding clips
- Good Auto Insurance. In your opinion. That you may have.
- tire question
- Gas leak!
- Installing Coilovers
- Intake Manifold Pressure question
- AEM short ram vs cold air intake
- Adding AC to a 99 civic
- do they make this?
- Quick VTEC Verification Image
- Civic will not go into gear :(
- Mini Me swap ecu problem
- u got a 4dr show it off leave 2-3 pics
- Vtec Controllers
- Is this the Type R Lip Kit?
- I have water issues
- Quick Engine Mount Question
- 95 EX crank
- Those with Optima Yellow Tops in their civics...
- Dumb Question
- 99/00 Civic Si Read Disc Conversion into 99 EX Checklist
- About to buy a new car, getting rid of my CRX
- not a related question but i wanted your opinion?
- wheel problems
- Belts Snapped
- mini-me info...
- I replaced the bearings in my turbo..
- Civic Hatck
