boosted 00 si ????
Old Jul 4, 2006 | 06:24 AM
theonlysi1's Avatar
theonlysi1
Default boosted 00 si ????
I am running a fully sleeved motor b16a with darton sleeves a str racing intake and fuel rail with 750cc rc injectors with low compression 8.5:1 turbo pistons a toda racing t belt and oil pump moroso oil pan magnacore 10mm wires msd 6al digital box cap and blaster ss coil, a slightly ported head with oversized valves adj cam gears crower ti retainers and valve springs not sure which set tho with a gt42 turbo and should be seeing around 25-30psi i was wondering if it would be worth the money to invest in a set of cams or just run the stock si ones i am looking to make around 500-700 horsepower and any ideas on what clutch setup to run i will be using the car on the street once and a while and prob drive it to shows
Old Jul 4, 2006 | 07:48 AM
2gr84u's Avatar
2gr84u
2gr84u
thats an awful lot invested into a turbo project to not be able to answer those 2 very simple questions for your self. A set of cams is a good idea in a build as exstensive as yours, and can help you get to the numbers your looking at at. To hold that kind of power your gonna need atleast a 4 puck, but you might end up needing a twin disk set up.
Old Jul 4, 2006 | 02:39 PM
ElCoqui19's Avatar
ElCoqui19
This will probably help you out, www.homemadeturbo.com ,good luck.
Old Jul 4, 2006 | 04:03 PM
ninohonda's Avatar
ninohonda
Goddamn 500hp ur lookin at a lot of tickets
Old Jul 4, 2006 | 05:14 PM
ariza034's Avatar
ariza034
SuMaDiNaC
oke...... :S
