timming problem! help!!
Old Jun 20, 2006 | 08:26 AM
itrdc2's Avatar
itrdc2
Default timming problem! help!!
Well ok guys when i try to do my timming with my car a 97 hatch w b16.
i hooked up the timming light and when i timmed it to white mark was aligned but the distributor was all the way back which is retarted right. What could be the cause of it? i never tried to drive the car because im concerned about it.
thanks in advance guys!!
JD
Old Jun 20, 2006 | 09:44 AM
waaBAAH's Avatar
waaBAAH
there are a total of four scratch (white) marks for timing. three are real close together....te last one is farther away from the bunched 3 marks. when you set timing with the installation of the timing belt. you have to line up the last alone mark with the crank pully. then when you check the timing with the timing light....you match it accordingly to the three marks. middle is zero and the other two marks (from that 3) are 15 degrees or 5 or whatever.
