Teg into Si
I was just wondering about putting a GSR engine into 99-00 Si. I was told that the rear engine mount is not lining up right. You have to get the mount kit or just weld it into the Si bay. How close to the truth is that?
Also, is the GSRs cluster swappable into Si? And while I'm at it - leather interior swap along with the arm rest etc.? Is all that interchangeable? Oh and forgot to add the steering column to the list, also changeable? Thanks for any input guys!
Originally Posted by Seruy
Tried, got LOTS of shit.
you can swap anything into anything, its all a matter of time and money.
i have seen geo metros w/ big block v8s.. convertible honda accords.. awd evolution 8 honda crx's, ect ect..
Searching actually requires some reading...
In fact I found these in less than 30 seconds
https://www.honda-acura.net/forums/s...d.php?t=240079
https://www.honda-acura.net/forums/s...d.php?t=238067
Like OMG! They were stickied right up at the top of the forum!
h:
Check that link again, search for cluster ( Ctrl + F ) you will see a DIY for GSR Cluster for an EG, you should be able to use that as a basis for a EK modification
