96 wont start
i have a 96 lx civic i just droped a 97 1.6 in it. it will crank but not start. i have fule to the rail and spark just wont turn over. i think my fule injectors are not coming on. if i spray ether down the intake starts right up. will not having the right O2 sensors couz this? or should it just run crappy with out O2 sensors? dont want to drop the $ if i dont have to thanks
Here's what I did to check my injectors. I had a friend in the car, I took off the fuel rail and held all the injectors on with 2 hands, as tight as possible, I had him turn on the car, and prime the fuel pump, after there were no leaks, I had him crank the car, then I saw each injector fire the right way, try that, if 1 or 2 injectors is firing weak that is def your problem. Kind of a ghetto way to figure it out, but when you dont have professional equiptment at ur hands you think of things. Let me know how it worked out.
ok i bought new O2 sensor today ( i needed them any way ) and hooked them up then i had 2 ex fule injectors on hand ( how lucky ) switched them with 2 on the car and gas came thought the others so yes i have cloged injectors guss i need new ones now thanks for everything guys
u have been a big help i bow to u
