water temp. ???
Old Jun 16, 2006 | 09:07 PM
displaybikes's Avatar
displaybikes
Default water temp. ???
what is the normal water temp. of a gsr after it's warm......
Old Jun 16, 2006 | 09:08 PM
displaybikes
and whats way to hot???
Old Jun 16, 2006 | 09:45 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Anything over half is dangerous. As for GSR's I know that in Civics with the stock 1/2 size radiator they usually are at 1/3 temp. I'm not sure about the long radiators though.
Old Jun 16, 2006 | 09:57 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
170 degrees F is the normal operating temp. The thermostat is fully open at 194 degrees F, so it shouldn't get hotter than that.
Old Jun 17, 2006 | 01:39 PM
displaybikes
so what does the red zone start at on the temp. guage... like gasket failure temp.???
Old Jun 17, 2006 | 07:09 PM
Provocateur
On permanent hiatus
It means pull the fuck over, you don't have any coolant. You risk melting something, warping something, blowing something, etc. Unless all your coolant leaks out or your water pump fails, it should never get up to the red area.
Old Jun 17, 2006 | 08:51 PM
displaybikes
yea but what temp. is the red area start at?
Old Jun 18, 2006 | 12:19 AM
Omniscient's Avatar
Omniscient
Thermostat opens around 1/3 which is about 200 degrees or 197 or something.
