what cams to run in a b16a turbo
Old Jun 27, 2006 | 02:14 PM
theonlysi1's Avatar
theonlysi1
Default what cams to run in a b16a turbo
i wanted some ideas on what cams to run in a boosted b16a looking for lots of power and around 20-30lbs of boost motor is ready for it just dont know what cams to run
Old Jun 27, 2006 | 06:37 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would recommend ITR or CTR cams. The higher lift and duration will make more power than B16 cams, but won't have excessive overlap that would require it to be tuned out with cam gears. More power could be made with cam gears, but they won't be a necessity.
Turbo motors don't need huge cams to make awesome power. 700 whp + has been made with a bone stock B16 head, so unless you are trying to push some extra power out of a turbo pushed to the brink of it's efficiency, stock cams are more than enough.
Old Jun 27, 2006 | 06:51 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Don't beefy cams need high compression?
Old Jun 27, 2006 | 09:59 PM
raiden571's Avatar
raiden571
turning u inside out
or gsr cams if u cant afford itr or ctr cams
Old Jun 27, 2006 | 10:24 PM
dank24's Avatar
dank24
stage 1 also, or thats what skunk 2 says
Old Jun 27, 2006 | 10:29 PM
qtiger's Avatar
qtiger
Only difference between b16 cams and gsr cams is a little duration, which isn't going to do a FI setup any good.
Old Jun 27, 2006 | 11:05 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I would run stock cams and see how your powerband looks before buying new cams. Odds are, the stock profile is pretty close to what you're looking for anyway. If you don't have the stock cams, I'd find a set of used CTR/ITR cams.
Old Jun 28, 2006 | 04:51 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
My buddy just basic tuned his car to 14 psi and he is at 360whp. Stock b16a2 in a em1. HE will be getting a high boost tune soon so he is around 420whp.
Old Jun 28, 2006 | 09:37 PM
raiden571's Avatar
raiden571
http://forums.evans-tuning.com/viewtopic.php?t=2341 may the force be with you
Old Jun 28, 2006 | 10:30 PM
Provocateur
On permanent hiatus
Nice link.
I had no idea that it made THAT much of a difference. Just imagine properly tuned ITR cams over the GSR cams. I have seen over 100 whp gains on very high HP motors just by switching from B16 cams to ITR cams.
