- pissin me off
- help!!! engine swap problem
- interoir paint
- What is this???
- Speedo, hazards, blinkers NOT WORKING! HLEP!
- Oil on plug threads (OMFG)
- 96 civic
- Let me try this again - CEL problem!!
- oil on threads of sparkplug.
- Check out this BAD machine....
- Valve Cover Gasket
- Keyless Entry and Alarm Not working
- Civic 98 coupe please help
- eg hatch spoiler
- HELP 95 gsr CANaDian GAUGE cluster swap into 1992 honda civic si hatchback
- body parts swap
- Cold start, starter sounds bad, won't start, warm no problems
- Blow-by, idling problem
- Intakes Question/Opinions
- Nothing
- Ugh...maybe someone can help me again..
- Please Help Me!!!!!
- 99-00 civic headlights
- elusive vibration. need some brake gurus here.
- Can Anyone Help Me
- Side Markers & Shift Boot Help!!!
- Update
- ac
- which valvetrain to run?
- >>>>>>best side skirts 4 EG6<<<<<<<
- Stainless steel header maintenance
- 93 civic mirror Q
- Calling SRS airbag experts.........
- 96 civic questions
- LED wing mirror wiring
- do they make 96-00 civic sedan m3 trunk spoiler
- WTB: B16 or B18C full swap or whatever you got
- As my luck continues on that steep slope.
- B16 Alternator in EG
- throttle cable problems
- 97 Honda civic factory alarm overide.
- '95 Honda Civic Del Sol Speedometer cable bad?
- Aftermarket Tail lights
- Help with "how to" on replacing Ignition Switch on 94 Civic?
- JDM del Sol Parts
- 00 Si acceleration trouble
- Bad Oxygen Sensor?
- Aftermath of changing the cv axle and lower control arm ball joint.....PLEASE HELP!!
- Civic Tranny Swap
- head gasket... crap..
- F/S 99-00 Si Wheels
- idling
- Wtb Or Trade Del Sol Seats
- idle problem
- rims?
- turbo people... read this please.
- radiator leak
- CEL issue - Help!
- '92 vx brake light/horn problems.
- Installing new springs,, how to tell the difference?
- The best seats Honda ever made!!!
- H22a or H23a
- Wiper Skipping!!
- Is it in fact possible?
- What can cause rough idle and almost stalling?
- Irregular accelarator
- Power Probs
- installing rotors and pads on 2000 civic si
- Need advice on fixing my eg :(
- b18a1 into 94 civic EX soupe
- part numbers for 1993 civic ex
- tell me more about hondas
- 99 civic auto to manual?
- Slight hesitation when starting car?
- Jumping around idle problem
- Struts
- Speedometer kicks on and off!
- Mail relay??
- EGR VALVE anyone?
- Integra front end
- Integra front end
- Intake manifold
- coolant reservoir..
- 94 civic SRS light
- headlights nee some help
- Question about Civics and Integras/acceleration difference
- Horsepower
- Need assistance change fuel filter 94 civic ex coupe
- need paint job on eg6
- B16 swap quick Question
- Alternator Brand
- 06 electronic throttle questions
- Help needed for Stoping AC leak
- 94 civic brake pressure
- 94 civic cv change Q
- HOnda accord 95 ex help needed
- ITR Cluster into EC CX Hatch
- Quick question about transmission mount
- Sedan CF Spoiler
- buddies car wont start
- Squeaky noise when pushing in clutch pedal
- bad luck last night.
- My New Del Sol: Please Vote!
- brand new clutch making noises???
- Weird sound while driving. Goes away when clutch is engaged.
- car stalls (or doesn't start) after sitting
- HAN need your HELP. H22 swap in 97 Hatch.
- boost to fuel pressure ratio
- Replacing gauges
- Civic 96 Dials gauge swap?
- Honda civic lx
- 00 Civic stumbling on acceleration
- cluster
- Primary O2 sensor help
- Carbon building up in the throttle body and idle valve?
- 98 Civic EX w/ b18c5 what exhaust to get
- How much of a perf gain with new headers and intake?
- hydroplane = curb
- Road Trip Pics...........
- Fresh Paint! 92 civic hatch
- help anyone
- 1994 Civic Ex Sedan... 4 Door Love!!!
- b20 swap into 94civic ex
- engine swap help b18a1 into a 95 civic dx
- effects of adding intake manifold
- I have a problem!
- automatic shifter getting stuck
- removing old gasket from intake maifold.
- Tony's Weekend Track Video
- Has anyone ever made an intake?
- need more speed
- turn signals dont work, need help!
- 1998 Civic is jerking
- b16 with turbo >?
- 92 Civic hatch OEM side skirt issue.....
- civic interior
- 95 Civic Dx
- anyone in the columbus ga area??
- CAI question
- Knocking or clucking noise
- trailing arm bushings
- seat dimensions
- APC rpm meter not working..
- What kind of turbo do I need?
- del sol rack and pinion vs civic
- del sol and civic windows
- My compression numbers.
- What kind of wheels r these???
- del Sol B18C1 Swap Question
- About my valves.
- Shark Fin Antenna
- 97 Civic problem
- Check this out!!! California!
- Smog on USDM motor swap, without B.A.R
- Air Horn issue...
- civic (swap) help here
- 2 issues; Rattle when AC is on, and E-brake light turns on when I accelarate hard
- intake manifold sizes
- quick question about window tinting.....
- help me out here
- Front End Shaking.. Help!!!
- bahh...it wont start
- clutch kit
- clutch pedal
- antenna
- power window connection problem!!!
- swap info and a whole lotta stuff
- Emergency brake issues. (E-Brake E brake)
- problem removing rear stabilizer
- annoying clicking....no power windows :(
- Tinted Windows.... Jdm Or Not???
- fuse confusion
- keyless entry--repost
- HELP! keyless entry problems!
- Front end problem!!!!!!!!
- Question: Body molding for conversions
- does dsm injectors work on hondas?
- Ever seen/used a rotor like this?
- Can anyone recommend a good wheel repair shop in the Bay Area?
- B16A2 with stock tranny?
- Just test-drove a 2003 EX...
- '96 Civic LX security system and power lock question
- Install help!
- So whats next????
- Stuck caliper/brake update (w/ pic)
- driver front wheel bearing
- Rack and Pinion Steering
- Window Regulator
- Tires for 18's?
- 96 civic ex pwr window stop working
- Do I need to get both?
- need help on possible broken fuel/temp gauges
- Sirius Radio in a civic
- B20b block with a B16a2 head compression question?
- Another P08 question
- suspension difference between generations
- 97 Civic Factory Alignment Specs...
- 98 headlight switch
- HKS Hi-Power Exhaust!
- degreasing engine, what do I need to cover up?
- Replacing windshield trim/moulding
- HELP: EG coup catback exhaust on an EG hb
- thermal R&D fitment question????
- 1999 Civic PCV Valve Location?
- 1997 HX Problem.
- Dragging caliper maybe? Metallic sound, brake smell, goes away w/ brake apply
- 2000 Civic Coupe EX
- exedy clutches off ebay?
- ??pwr steering install??
- putting mesh on a lip (fiberglass)
- VAFC question
- DRL Light and Handbrake light on
- Is This Particular DYNOMAX Exhaust Too Loud?
- new in to honda"s?
- my car misfire on 3 and 4 cylinder?
- Fan not working
- 0-60 times?
- I have a brake question?
- Looking into buying a used civic
- New guy: need advice on H22 hatch
- What Is The Best Turbo Kit?
- Another lug nut ? (links attached) will they fit?
- turbonetics drag 3 kit on civic si
- EJ1 (95 Coupe) Rear Seat Swap
- Cant find freon leak?? (100 in vegas)
- No Spark need help
- 97 civic, check engine light...?
- tranny fluid
- Something under dizzy cap went bad? :O
- True Or False......
- real fast suspension question
- Top mount Peakboost kit
- cluth will not completlly disengage
- running on two cyl.
- head job
- Dash Removal?
- CEL question
- Dash Removal?
- 98 ex coupe test pipe in a 93 ex sedan?
- daylight lights
- Need help with Ls Vteck swap
- NGK plugs explained
- Question about J&S safeguard and oil coolers
- Where to get some bolts (to replace rusted ones)
- 95 Civic Halfshaft Seal Problems
- 1995 Civic Transaxle Seal Leak - Help!
- Eg Chaser!!!!!
