No Spark, solve this problem!
Old Sep 27, 2007 | 06:08 AM
Running925's Avatar
Running925
Your Powder Coater
Default No Spark, solve this problem!
Had a kid call me & said his car wouldn't start. I went throught the normal questions so heres the details.
1. Fuel pump still primes
2. there is pressure at the rail
3. you can smell fuel when u crank for a while
4. Found NO SPARK
5. pulled the dizzy & stuck it on my car & it fired right up, (so his dizzy is good)
6. put a new ecu is his car & got same responce. (no spark)
7. ecu fuse is fine
8. your turn!
Old Sep 27, 2007 | 09:44 AM
dieneverknowing's Avatar
dieneverknowing
Did you guys check to make sure the plugs and plug wires are good? I'd imagine you would have but it wasn't mentioned.
That's the only thing I can think of within my minimal expertise. Hope it gets worked out though.
Old Sep 27, 2007 | 10:42 AM
Running925's Avatar
Running925
Your Powder Coater
there is no spark comming from the distributor while it's on his car, meaning there is no spark to give to the wires, let alone the plugs that are even further down the line.
Old Sep 27, 2007 | 10:45 AM
Wharbone's Avatar
Wharbone
Grounds?
Old Sep 27, 2007 | 10:55 AM
dieneverknowing
Ahh, I just assumed since the distributor functioned on your car it would function on his. So I just stepped passed that and carried on aimlessly towards the plugs & wires. h: Guess the problem is the other way? :hsdunno:
Old Sep 27, 2007 | 01:12 PM
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by Wharbone
Grounds?
checked & even went as far as grounding the engine & chassis with jumper cables to make sure!
Old Sep 27, 2007 | 03:25 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Any power going to the dizzy at the plug on the harness?
Old Sep 27, 2007 | 04:08 PM
mason rocket's Avatar
mason rocket
my 2 cense
how bout the coil?
Old Sep 27, 2007 | 04:18 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by mason rocket
how bout the coil?
Can't be. He swapped the dizzy to his car and it worked fine.
I'm gonna go with either a relay or some wiring.
Old Sep 28, 2007 | 05:15 AM
Running925's Avatar
Running925
Your Powder Coater
haven't done any power testing yet, looks like thats what it's gonna come down to tho. I need to go back over there with my volt meter.
