440cc injector
Ok i got a 95civic with B18A1 swap from 93 teg.i got header,cai,xspower intake manifold, hydro tranny from 94LS, stage 3 clutch with 9.75lbs flywheel .... My question is 440cc injector is to much to this set-up or what?
why are you being a douche bag?
he is asking a simple question and the answer is yes they are too big. you should buy some sort of fuel management like a vafc and a wideband before you get anything else. it will help you get more power out of what you have already
Because I was abused as a child.
Agreed, but I would highly recommend a chipped ECU over a VAFC. It will cost less and allow you to directly control timing.
I honestly wouldn't worry that much about tuning it with only bolt-on's. Once you throw in cams, higher compression, or some form of forced induction, then tuning will take priority.
Yeah, sorry, I thought that tuning was implied. You'll have to tune the chipped ECU or the VAFC properly, whichever route you take. Of course, this means using a wideband o2 sensor, as you mentioned, and not just pressing all the pretty buttons.
