Problem Starting
Old Aug 16, 2007 | 02:12 PM
cltypes32's Avatar
cltypes32
Default Problem Starting
Have a 92 si w/d16z6. The car will start perfectly when cold. But, after you run it for a while, cool off a bit, not cold, it will take 10-15sec of cranking before it will start up again. If I restart right away no problem.
I've replace the fuel pump, fuel filter, plugs and pcv valve.
What else can it be? Coil and or the ignitor?
Thanks in advance!
Old Aug 16, 2007 | 06:55 PM
A-series's Avatar
A-series
v-card member alpha
Can't say for sure but that sounds like it could be the coil, I had a similar issue on a few occasions a while back.
First I thought it must be the main relay and then it didn't happen again for a long time so I thought it must've just been some bad gas but there were a couple times after that when it didn't start up "normal".
Finally my coil died - started up fine and idled for 5 seconds before it quit - and since replacing it I haven't had the issue again.
P.S. Your tach isn't reading noticeably off is it? If it was, which mine had been doing, that would all but confirm (to me) that it's something related to the coil or ignitor/ignition module.
Old Aug 17, 2007 | 11:14 PM
ari_one's Avatar
ari_one
I'd check the injectors, they could be leaking onto your plugs and getting them too wet. They would dry off after a while and wouldn't get wet enough until you let it sit for a couple of minutes.
