Heating Control - Civic Tropica 2000
a bit new too all this and wondering if anyone could give me some help working out how to fix the heating control on my car. the basic problem is that the fan control works perfectly but the temperture slider will not go to the cold side!!! meaning i've got to sit in the car with all the windows open as its getting far too hot in there.
can anyone assist in giving me a clue on how to fix this without having to take it to the mechanic.
cheers in advance!
cheers in advance!
You have a 2000 and you have the slide adjustment? I was under the impression that 99-00 had the turn knob for temp control?
If you have the knob, I'm not sure why you wouldn't be able to turn it to cold.
If you have the slide (pre '99) which is operated by a cable (at least it was in my 98) then check behind the console/bezel to see if anything is messing with the cable. If nothing is messing with the cable, disconnect the cable from the control and see if the slide works period. If it doesn't slide, there you go. If it does, then your problem is somewhere else probably.
Just some ideas
Just some ideas
