HELP H22A EK .. shift linkage problem
Hey guys can anybody help me out ... there seems to be a prolem with my swap ... the shift linkages wont work no more .. FOR THOSE OF YOU FAMILIAR WITH THESE SETUPS, ONE CABLE WORKS THE SHIFTER RIGHT AND LEFT AND THE OTHER UP AND DOWN, THE RIGHT AND LEFT CABLE IS EITHER BROKEN OR STUCK, BECAUSE IT WILL ONLY SHIFT FROM THIRD TO FOURTH. I WAS TOLD THIS WAS THE PROBLEM WITH THE TRANS AND IT LOOKS TO BE TRUE, WHEN YOU MOVE THE SHIFTER RIGHT AND LEFT THE LITTLE BALL ON THE SHIFTER POPS OUT OF THE CABLE HOUSING THAT MOVES UP AND DOWN. (SEE PIC FOR BETTER DETAIL) I WAS TOLD THAT THIS WAS AN EASY FIX, CAN SOME ONE HELP ...
THANKS
THANKS
