Programming Remote Key
Old Aug 6, 2007 | 04:53 PM
kws's Avatar
kws
Default Programming Remote Key
I Have A 2007 Acura Tl. One Of The Remotes Was Not Programmed To Lock, Unlock The Doors And Trunk.
Do You Know How To Program It?
Kws
Old May 22, 2008 | 06:57 AM
CHUCKPRO's Avatar
CHUCKPRO
Default spark plug seals
hello, I have a 93 honda accord, and wondered how hard and what special tools do i need to change spark plug seals? I have oil in three out of the four spark plug boot areas. and do i have to remove the valve cover to fix the seal problem chuck pro
Old May 27, 2008 | 11:23 AM
JimBlake's Avatar
JimBlake
You have to remove the valve cover, but that's pretty easy. The spark plug seals are kinda like part of the valve cover gasket, they fit around the sparkplug hole. A valvecover gasket 'set' often includes these, but check to make sure.
If it continues to leak, it may be from the lower seals. For these you have to remove all the rocker assemblies & camshaft bearing caps. That makes it a much bigger job than the valve cover gasket.
