Radiator Core Support How To Please Help!!!
Old Aug 28, 2007 | 12:26 PM
tx95excoupe's Avatar
tx95excoupe
Default Radiator Core Support How To Please Help!!!
Does anyone have a how to on how to change the radiator core support out on a 95 ex coupe? Also will the radiator core support on any model of 92-95 civic fit a 95 ex coupe? I also thought of dong the Integra front end conversion since I have to change the front end anyway. Which one would yall recommend, and which one would be easiest, or are they both about the same as far as labor goes?
Old Aug 28, 2007 | 04:10 PM
m735is's Avatar
m735is
I'm not sure about the interchange between the coupe and sedan. Call an aftermarket panel shop or even the dealer and see if the part numbers are the same.
As far as replacing it, it's pretty self explanatory, just start unbolting everything that's attached. The only thing that may give you a problem would be the spot welds tht hold it to the frame rails. I drilled those out.
