View Full Version : '92+ Civic/EL & Del Sol
  1. better air flow for intake?
  2. suspension question
  3. fuel getting cut off??
  4. need help... integra dash in civic
  5. teg front brakes, is it worth it?
  6. 95 civic question
  7. Dynamat
  8. Stripped screw
  9. GSR swap
  10. car stolen in middletown new york
  11. Civic EX - Horsepower Question
  12. Decent Shop in North Phoenix
  13. header/cat gasket
  14. need help
  15. '99 Civic Coupe rear bumper cover replacement
  16. 07 Si muffler fit 96 DX Coupe?
  17. Transmission code.
  18. Caliper rebuild
  19. knocking pistons while accelerating
  20. good place for turbo rebuild t3/to4e 60 trim
  21. What to do with my 94 Civic
  22. *** Stolen 92 Hatch Long Beach, CA area ***
  23. Summit Racing > ES
  24. oo rod bearing
  25. Will this Neuspeed Strut Tower Bar fit in 99-00 Civic Si?
  26. 00 y8 head making noise
  27. Where can I install my game system at in my 95 honda civic?
  28. 1995 Honda Civic
  29. Tokico Shocks diagram
  30. civic won't start, cranks with spark/fuel.
  31. Automatic Transmission Question
  32. Power Steering Rack replacement
  33. question about turbo kit
  34. EX Cluster in 96 DX Car. Have problems
  35. Car won't start.please help
  36. Looking at 7th Gen Civics
  37. Misfiring
  38. head gasket replacement/head question
  39. 01 Civic 4dr
  40. camber fix
  41. Front and Back Brakes
  42. Headlight help
  43. New Hearders Question.....
  44. Suspension setup civic
  45. Best Auto Part Brands for Hondas????
  46. 1995 Honda Civic Ex 2 Door Black
  47. leak by driver side footwell
  48. installing new fenders on 95 civic
  49. Lock Actuators
  50. Building a d16y8 What kinf of ECU can I use? or the p2e should be fine?
  51. Official Brake and Light Adjustment Certificate Location??
  52. transmission gear swap & lsd install ATTN: Tony & Lee
  53. gsr swap (motor mount ?)
  54. The BEAST Build. My Quest for 10's
  55. speedo won't go back to o.
  56. ? for those w/ eibach rear sway bar re: exhaust
  57. 1993 del sol si Ls swap
  58. Mini me swap
  59. oem clock in eg dx?
  60. 01 Civic A/t tranny problem
  61. what brand "OEM JDM" fogs for 96?
  62. Check Engine Blinking?
  63. Oil pickup gasket?
  64. Took up smoking part time
  65. Smelly air vents
  66. what causes ignition control module to fail?
  67. Sputtering, coolant loss, overheating
  68. WTB 99-00 Front End Parts
  69. b16swap
  70. (Noob here) What causes fogging lights?
  71. 2000 si won't stay running
  72. B16a2 to a 1996 Civic Cx
  73. Timing Check question
  74. 99 d16y8 into 97 hatch - which wiring setup to use??? PLZ HELP
  75. Catalyctic
  76. Coilovers installed incorrectly?
  77. car wiring
  78. What Motor to Swap
  79. gauge installation
  80. NGK Blue Wire Fit for 96 DX
  81. 00 Front End Conversion
  82. 2005 Civic LX vs EX
  83. 98 Civic Automatic to 97 Integra Automatic
  84. 96-00 stock exhaust; eibach rear sway bar clearance issues
  85. 1999 Civic SI Horn Problems..
  86. del sol mirrors
  87. S20 transmission
  88. Really need your help!!!!
  89. 95 civic spearkers?
  90. abs kicks on at 5-20 mph
  91. Clutch Question
  92. Will a 13" wheel fit my Civic EX (Help)
  93. 2000 civic kit help
  94. Is replacing a/c compressor yourself and getting the system to work >?
  95. ek3
  96. Rear disc conversion
  97. 93 EG Lowering springs
  98. Frankenstein
  99. DOHC Vtech del sol,1997
  100. ITR coilovers on EG
  101. D15B 3 way vtec ECU
  102. car wont turn over please help
  103. apexi vafc ?s
  104. 94 Honda Civic Ex Coupe
  105. New Hatch Version 6
  106. Wiper Problem??
  107. 96 civic gear shifter problem
  108. Crappy Day V. HatchVX v. 2
  109. Keep 91 CRX or go EG hatch
  110. ECU connector location
  111. Car wont crank after sitting a month? Help
  112. 95 civic need suggestions
  113. DOHC VTEC Del Sol.. How rare?
  114. head gasket change
  115. New Member
  116. non vtec to vtec
  117. Genuine Italian leather shift boots - custom made for your car!
  118. Spun a rod bearing... now what?
  119. No Spark or Signal To Coil: 96 Civic EX
  120. Just looking for some opinions
  121. Oem 99 00 Civic Si Springs and Shocks
  122. Strut/Springs questions regarding 2001 Civic
  123. EG-Sunroof window flew off on the freeway...
  124. Starting issues
  125. 06 civic shifting issues
  126. 95 civic interior redo customization
  127. want to make my ek look like a touring car
  128. S4C Transmition
  129. ITR Exhaust on 96 Civic Coupe?
  130. RH CV axle not clicking into position
  131. About to hit 90K, maint?
  132. 99 Civic, should it have a light alarm?
  133. Cleaning the pipes
  134. ,...
  135. 06 civic price question
  136. Can I put a P28 ECU to a OBDII engine?
  137. Ground Control Coilovers.
  138. Crappy day yesterday
  139. shift linkage question
  140. rear disk brake question
  141. Oxygen Sensor Question
  142. Fuse location for side mirrors 96 civic ex
  143. Buddy Club N+ Damper opinions
  144. Front strut replacement on a Civic
  145. Question related to timing belt change on Civic.
  146. Is this true regarding recommended fluids for Civic?
  147. where did I mess up?
  148. 2006 Civic Wiper Replacement...
  149. Wanted: Honda enthusiast in Tucson area to help w t-belt
  150. 2001 Civic Coupe Hub Cap Removal Help
  151. 96 Civic DX woes
  152. lower ball joint
  153. 98 Civic...won't start, will start, won't start, etc.
  154. 94 civic body going price
  155. 1999 civic grille
  156. Skunk2 vs Koni yellow ground controls
  157. d15b jdm vtec specs
  158. honda trailing arm bushing xtractor
  159. How to install Cold Air intake for Civic 2000 ex
  160. obd1 civic throwing 41 and 16
  161. Im lookin 4 help about buyin a 92 civic, im sellin a 99 integ SE, swappin technically
  162. 94 civic HB CX- What do I need to get these things fixed?
  163. 1995 honda civic hatch
  164. Skunk2 COil covers....help
  165. 03 Civic Transmission HELP!
  166. Help with Skunk2 coil covers!...for 04 civic lx
  167. 95 Honda Civic installation help
  168. Wide body
  169. 00 SI stolen...
  170. H22 Swap Help!!!
  171. Integra brake swap question . . .
  172. 99 Front End
  173. Suspension
  174. SI Front sways NEED HELP!!!!
  175. 1993 eg6 electrical problem
  176. 1999 civic si
  177. Thinking of a used Del Sol - what to look for ?
  178. EL door
  179. 01 civic ex sedan factory alarm no sound?
  180. swapping 01 civic LX to EL front bumper
  181. b18(turbo)/b18(2ltr stroke & turbo)/k20(toda)
  182. 99 Civic Si Idle Problems
  183. San Diego: Thinking of buying a 2007 Civic. need owner advice!
  184. HELP please. obd1 engine into obd2 car
  185. Del Sol Civic Transmission Help
  186. would rsx coilovers fit on a 99 civic??
  187. Headlight issues
  188. 98 Civic type R Grill....
  189. Mysterious vibrating noise! help!
  190. CEL on
  191. Del Sol handbook re dash warning lights
  192. Resister box install
  193. changing from 14x5 to 14x5.5 rims.. tire q?
  194. Basic parts
  195. b20vtec (semi build) sparkplugs
  196. Cold Air Intake
  197. Coilovers
  198. Hood latch problems...
  199. Falken Ziex ZE912 tires
  200. MAP Sensor for 96 civic
  201. 1995 Civc DX 4DR MPG & O2 Sensor(s)
  202. Greetings from Mexico City
  203. does nobody know how to erase this code??
  204. 95 si
  205. TWM Performance Del Sol short shifter
  206. d16 engine overhaul vs. swap
  207. d16 engine overhaul vs. swap
  208. Power Lock not working after power window conversion!!!
  209. interior question
  210. 95 civic coupe suspension rebuild
  211. dash light question
  212. Distributor for B16 in EG
  213. Any ideas?
  214. HELP 97 Civic Won't start no more :(
  215. CarFax
  216. power loss 95 civic EX
  217. CEL or Check Water Pump?
  218. Del Sol warning light
  219. Aftermarket Radio/Keyless
  220. 95 civic questions fiberglass work interior
  221. Help please!?
  222. front grill help...99 civic
  223. 95 civic interior painting questions
  224. clutch is to the floor. help
  225. Spring Rate
  226. turbo, all motor or, nos??
  227. 98 strut bar question
  228. 94 Civic Headling Not Working
  229. 93 Honda civic axle help
  230. my 98 civic is overheating
  231. RHD CONVERSION QUESTIONS for 95 civic coupe
  232. E Brake Questions HELPPP
  233. cant unlock doors from outside
  234. trouble starting my sol
  235. '02 Civic EX 4dr. w/AT - need motor mounts?
  236. del sol warning lights
  237. del sol warning lights
  238. Catback
  239. Cracked exhaust manifold help.
  240. iac valve help
  241. 95 Civic CX to EX Questions
  242. Quick fuel prime, kinda?
  243. motor mounts
  244. New Project!
  245. brake set up swap from teg to civic... NEED HELP...PLEASE!!!
  246. Alarm Help
  247. Powder Coating: first try
  248. hammer question
  249. 98 Civic HtchBk with Hi Pitch Squeal
  250. Exhaust System
go
