99 Si Ecu reset- Which Fuse?
slow lane cruiser
Hey anyone i'm trying to reset my ECU because I lost my gascap I've got a new one alredy but I dont Know Which fuse to pull.
I'm more accustomed to my integra, I just had to pull the one labeled ECU.
In the Si is it the one labeled FI E/M I'm assuming E/M means engine management?
Thank you to whomever in advance. Gabe
v-card member alpha
In the underhood fuse box, there should be a fuse labeled ECU (diagram should be on top of or under the cover for the fuse box, most likely) and might also be one labeled "back-up". Remove those (or just ECU if that's all you find).
That should take care of it, otherwise just disconnecting the negative battery cable of the battery for 30seconds. will definitely do the trick.
