92 civic DS window wont go up or down.
hi, i will get to point right away. the driver side window on my 92 civic wont go up or down, i have checked the motor, master switch and all the fuses they are all good. i dont know what would be wrong.
connected to the battery it self. how i checked my master switch, i bought a new one and it did the same thing the old one was doing. i dont know where to find the relay or if there is a module. le me know plz any one.
first check if it has 12 volts and check for ground. and or check the window motor it has 2 wires. put hot in 1 wire. and ground in the other wire.both wires are the same. you can put hot or ground to either one.
i know it's a long shot, but i'm willing to bet you dont' have splash gaurds in your fenderwells... I checked everything you did, and everything was good.. passenger side window worked, and drivers side worked SOMETIMES, but not all the time.. turned out since dude man before me took out the fender linings, it had thrown sand and water and had actually ATE AWAY at the boot that covers the wires going from the door to the car, and water got inside and started to corode it.. basically fell apart in my hands when i found out that it was the problem.. if that's the problem, just go to the junk yard and grab you one and stick it in your pocket... around here they don't like you cutting the harness without buying the car, because they say that no one will buy the car (which is totalled) if any of the wiring is cut....
