99 civic fog light install help
Old Jul 9, 2008 | 05:07 PM
kini's Avatar
kini
Default 99 civic fog light install help
need help with already cut the bumper and hooked to foglight harness problems with the switch harness under the dash
Old Jul 9, 2008 | 05:36 PM
cpvdh's Avatar
cpvdh
more info needed
stock lights?
stock wiring?
i installed 96-98 stock fogs and had a hard time finding the harness under the dash, ended up being way down behind the pedal assembly tucked under the carpet
but the 99-00 fogs are different and if i remember correctly have a different wiring setup
here is an install guide for 99-00
http://www.handa-accessories.com/civ...cfoglights.pdf
Old Jul 10, 2008 | 05:26 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
If I remember correctly the factory harness plug is right underneath the fuse panel its a brown plug it doesn't make a difference in which one you plug into
Old Jul 12, 2008 | 08:34 PM
kini's Avatar
kini
thanks alot guys figure it out
Old Jul 13, 2008 | 01:19 PM
thetunersource's Avatar
thetunersource
awesome, im glad u got it fixed.
