View Full Version : '92+ Civic/EL & Del Sol
  1. '94 Civic A/C problem
  2. Good info on rear drum brakes
  3. Ludes
  4. need input on this ASAP!
  5. so cal mini me swap
  6. clutch replacement...
  7. Where to get rear LCA's?
  8. Turbo
  9. where is the main fuse 96 civic
  10. Auto to Manual
  11. sideswiped by 18 wheeler, totaled my civic (pics inside)
  12. Lightweight flywheels
  13. manifold question..
  14. need new headlights, are these good?
  15. axle question. can dynamic dampers relocated?
  16. Best Coilovers?
  17. 2001 Civic. Where can I jump it to figure CEL codes
  18. Civic Locks
  19. Need some advice please...
  20. Fitting oil pressure Gauge
  21. I woke up to see this:
  22. Low Oil Pressure WHY?
  23. B16a2 Sir 2 question
  24. Exhaust Question
  25. d15 project
  26. why is it overheating?
  27. LCA question on civic...
  28. Woot! I finally got the rear shocks together!
  29. spoiler install
  30. Upgrading the engine itself to a v6
  31. Transmission noise into first gear
  32. Leaky Windows! Suggestions?
  33. Ordering European headlight unit for 97 Civic.
  34. 95 del sol
  35. cannot start my civic
  36. Tire size?????
  37. Had a minor accident, need help
  38. Knocking noise from Rear suspension
  39. D15b tranny question
  40. NEED HELP on 88 civic heater motor relay
  41. Rattling noise at 3400rpm
  42. lights blinks...
  43. A/C Belt?
  44. Need help with tires.....
  45. sunroof question...
  46. Painting steering wheel and piece behind ?
  47. Ok, thats fixed, now what?
  48. Swap Shop
  49. just installed optional audio console-93 civic 4door
  50. i cant open my trunk!!!!
  51. lookin for rims
  52. Injector cleaning
  53. Honda ciciv 95 overheating
  54. ECU trouble!!! :(
  55. grinding when shifting into 2nd
  56. Cold Start Problem
  57. good glow gauges....???
  58. where to find good lip kits???
  59. do dealerships use impact wrench on crankshaft bolts?
  60. Help !! Keyless entry for 1998 civic ex
  61. Passenger side axle and tranny
  62. ls/vtec or just ls ???
  63. anyone ever have this problem?
  64. greddy sp2.
  65. interior lights?
  66. ct26 turbo?
  67. Which bulbs am I thinking of?
  68. Tachometer - RPM measurement
  69. 4 individual throttle bodies for a del sol
  70. Dashboard Speedometer back light replacement? (2001 Civic DX)
  71. Hub & Bearing Assembly
  72. check engine
  73. Need help ASAP.. tranny problems
  74. which lip is this?
  75. Turbo ?
  76. Axel Nut problem
  77. a/c compressor help
  78. Uh....uh oh....What should I do?
  79. Valve Cover Paint Job
  80. Strange Starting problem
  81. Should I buy a balancer and tire changer?
  82. I need to know which motor i have
  83. How long does it take for springs to settle.
  84. Question about header?
  85. how much to fix 93 honda civic shell
  86. good bulbs for projectors...???
  87. What wheels?
  88. Knock Sensor Compatible?
  89. Brake caliper help
  90. d16y7 with d16z6 head, wiring problems
  91. D16Z Heads??
  92. Has anyone heard of......
  93. jdm zc head swap?
  94. Engine Swap
  95. Parking lights problemo
  96. idle jumping around, just after puttin belt on? come on engine gurus
  97. Seat swap?
  98. New parts!
  99. does 92-95 civic shocks fit ek 96-00 hatchbacks?
  100. Hmm...damn Autozone.
  101. Need Advice 92LX won't start
  102. Help!!
  103. swapping gsr cluster into ek. need help asap
  104. Always me right?
  105. Oil dissapearing- D15
  106. Spoon N1
  107. No honk with keyless entry system on 99 Civic EX Coupe
  108. tein Flex or Omni
  109. 93 ex swap questions
  110. A/c problems in B18 swap into Civic
  111. Beeping Noise!
  112. 98 Civic Auto Tranny Issues
  113. all the crap I have to install
  114. Camber kit for neuspeed sport springs?
  115. low idle
  116. 5th gen A/C chatter
  117. Del Sol B18C1.....
  118. Vtec manifold used on non-vtec Civic
  119. stock 2000 SI shocks
  120. 92'civic Si hb
  121. price quote on auto to manual swap
  122. Muffler?
  123. s-afc hack problems
  124. Coilovers vs. Springs ??? what's the difference
  125. 2dr 4 dr trunk lid
  126. I CANT BELIEVE THIS!!!!check it out
  127. I got a question
  128. Spoon exhaust question
  129. maybe bad axle
  130. Problem with dash conversion wiring
  131. HElP!?!? NEW Clutch and pedal goes to floor.. help please..
  132. Looking at a Hatch, tell me your thoughts on it!
  133. D to B
  134. Cigarette lighter wire! Who to Pick?
  135. A Helping hand for NYC
  136. what engine?
  137. H&R OEM Springs
  138. Tial BOV
  139. Trade a D16 for a B16?
  140. wiring help
  141. Just rotated my tires, but now it rides badly? Unidirectional vs. Bidirectional?
  142. Rough ride. Bilstein Can i mak it smoother ?
  143. Front LIP question...
  144. Vtizzle
  145. Black car with black rims!!! posts pics
  146. One more time.
  147. Star Wars guy again.
  148. Any one seen Star Wars?
  149. D-series peakboost
  150. 10X84 bolt
  151. Steering wheel is making weird squeaking noises when I turn.
  152. exhaust pipe
  153. 98 civic ex clutch?
  154. LS/Vtec vs. B18c1
  155. what's wrong w/ my suspension?
  156. Power steering, help please
  157. Turbo B16b?
  158. B16 motor swap
  159. 92-95 Civic EX, rusting problem
  160. 92-95 coupe decklid cover fit a 92-95 4 door decklid?
  161. radiator burned a/c hose
  162. white out taillights
  163. want stiffer suspension, not lowered
  164. **read First Before Replying To Any Post**
  165. Turbo stuff...
  166. Yet another engine question???
  167. Question about CV Axels
  168. del sol with d16z6 head with a d15b block
  169. Basic EG Civic info needed !!!
  170. 1996 Civic LX problem
  171. B18B vs. B20b
  172. IAC Valve Bypass...
  173. B and D series interchanges?
  174. KYB Excel-G in a MA chassis code
  175. too much
  176. Civic Vti with navi screen
  177. Civic 6X9 Speaker Installation..Is it Possible?
  178. 93 civic misses.. ignition?
  179. B Series Throttle body on Civic??
  180. Eagle Rods and SOHC?
  181. Throttle Bottle stupid problem
  182. 1998 civic transmission problem
  183. Getting rims and tires
  184. mugen Voltage Stabalizer
  185. power window???
  186. 1997 Acura 1.6 EL Dash
  187. Code 20 and 23, Help!
  188. Weird shaking/vibration
  189. Need Help 72hrs What is this noise?
  190. Question about engine???
  191. Daymn... 700 buckz just to change brakes..
  192. apex'i turbo timer wires
  193. Transmission axle seal question
  194. P&P and Cams
  195. Odd rattle?
  196. Will HX wheels fit 1995 Civic Coupe EX?
  197. suspension techniques vs. comptech
  198. These rims are sweet to me, anyone else?
  199. She's Dead Jim....
  200. eg rear sway bar bars (cage) thingy ?
  201. Battery in Gas Tank
  202. Shock spring DIY?
  203. hood latch broken
  204. Easy D series question...
  205. Del Sol seats into a 95 Civic
  206. b18 swap and front end conv.
  207. simple question about rear lower strut bar
  208. B16A 2 is it worth it to go N/A?
  209. what do u think: bilstein twintube and h&r sport springs
  210. What Motor is in Every Del sol?
  211. Black boxy thing near the pedals needs some chrome
  212. Quick Questions About Intakes
  213. what motors could you swap into a 01 ex coupe?
  214. 99 si front end
  215. Will this type of wheel fit a 6th gen?
  216. Swap or Rebuild?
  217. 98' civic Ex SOHC D16Y8
  218. What shift knob is this?
  219. Where to buy b series swap mounts.
  220. Car is tilted
  221. brake pad replacement on 94 civic Si
  222. Ok, time to take care of that axle.
  223. Del Sol W/ a B16A2
  224. question about buying a 99 SI...
  225. Power window problem
  226. ignition problem... maybe fuse related
  227. Cheap 00' SI parts....
  228. engine problems
  229. 00 SI Front-End Conversion.....
  230. Vacuum Hoses
  231. Brake Rotor being a pain
  232. All Black Floor Mat for 6th gen Coupe?
  233. Need help on a jdm part for eg9
  234. For anyone who cares, I hit the dyno yesterday
  235. 05 civic dilemma lol
  236. Kicking muffler tip
  237. 2000 b18c1 usdm engine into a 95 hatch
  238. Starting Problems - 92 Civic
  239. 93 hatch vs 93 coupe???
  240. H&R sport springs for 93 civic ARE THEY COMFORTABLE?
  241. Civic,wheels and 4/100
  242. Smog a swap in CA
  243. Angle head cut
  244. lip question
  245. el 1.6 valve cover on a civic d16
  246. How to Install Apexi VFAC in 92 civic
  247. need some help
  248. major bogging at 3-4k rpms
  249. looking 4 98civic carbon fiber int door panels
  250. Vibration on drivers side
go
