preperations for turbo install???
I will be installing my greddy bolt-on turbo kit for my 2000 civic in the next week or two!What kind of stuff will i need to get it ready???i need to convert to 93 octane fuel, and get some oil since i will be changing that,anything else???
The kit is pretty inclusive. I do recommend stepping the heat range of your spark plugs down one and maybe picking up an oil catch can, but besides that, the kit should have everything you need to get the car running just fine.
Along with making sure your spark is working very well, you may want to (if using the stock fuel pump) rewire it with a heavier gauge wire, as this will allow you to fully exploit the stock fuel pump and possibly an ajustable fuel pressure regulator, Good luck with the install and remember- lean is mean, rich is safe.
