block drain in 00 civic si
Moderator Alumni
Standing in front of your car, looking toward the engine. The coolant drain plug/bolt will be right behind the header primary that is on the far left. You'll need to remove the heatshield to gain access to the area. You should not need to remove the exhaust manifold, but don't quote me on that.
2005 s2000
2005 s2000
You may be right. Im thinking of a single cam motor. Oops
