no EGR on D16Y8s...how is NOX controlled?
Old Jul 18, 2005 | 01:12 PM
civicfan8's Avatar
civicfan8
Default no EGR on D16Y8s...how is NOX controlled?
And how can we resolve issues with getting high nox in the exhaust ? thanks!
Old Jul 18, 2005 | 04:42 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
I have the same problem with my 00 Civic EX (D16Y8)... no egr system, it uses the PCV system. The only way to really control it is balancing the A/F ratio keeping it Stoich, and cooling the combustion temperatures down with a lower thermostat and cooler spark plugs.
Old Jul 18, 2005 | 04:50 PM
DJ Panic's Avatar
DJ Panic
Retard the timing to lower NOX, HC will slightly higher with less power and if you can't lower it by doing that, look on buying a three way cat.
