- white smoke help!!
- B16 head with B20 bottom end?
- Shorted wires somewhere. please help [DA* w/ B16 Swap]
- ls/vtec swap problems!
- Check Engine light - cycl. 3 misfire
- BOGGING PROBLEM!? Help please
- Problems, etc...
- How to clean O2 sensor
- need help anyone
- b16a2 vs. b18c1 vs. ???
- msd cap for b16
- How do i get more horsepower?
- Newb question!! Dont flame.
- Does a B16 IACV work on a Gsr?
- Pr3 Vs P28 Ecu
- K20A in a DC2 4 DOOR
- CRX Car Computer
- vtec higher cams aren't working...NEED HELP ASAP
- Radiator clearance issue...
- B20 bottom end Q's?
- First clutch/flywheel install - PICS OF DAMAGE - WHAT HAPPENN??
- H22 integra Swap... estimated time?
- Vtec controller?
- injector?
- electrical problems
- Help Before I Dyno Tune
- MAP Sensor Question ?
- Fine tune A/F?
- gsr internals in b18a1
- idle problem
- rough Idle in the morning
- turbo manifold
- is there a diff between vtec and non vtec wires??? (EG w/ B18B1)
- GSR swap
- Improved gas mileage...
- distributor swaping help
- 96 civic ex questions
- TL custom exhaust
- help~!engine swap problem [F22 into Integra ?]
- which head can get more hp
- honda injectors ratings
- Stage 1 cams.
- HELP! Something's buzzing under my dashboard!?!
- accord 91 dx ignition problem
- Project G21 commences
- Rarely Drive R
- How To: Nitrous on an Automatic ?
- Whos Running "jrsc" On This Forum?
- no fuel through injectors
- HELP! 5 speed swap problem w/99 Accord.3
- HELP! 5 speed swap problem w/99 Accord.2
- V4d?
- Stay away from Racingchips.com
- part 3 honda del sol issues
- weird idle
- Header help
- Muffler under water, engine stalled.
- active nitrous before or during WOT??
- ok car is running thanks but 2nd problem
- ABS pump question!
- z6 block...if i can use a y7 head, what ecu? can i use a p06
- Should i keep my type r cams in?need some head set up help?
- B18B vs B18B1
- motor for my 90 ls
- 4 specific questions on zex nitrous on hatch with gsr swap
- Which ECU for DD on B16A2...?
- Turns Over But Dont Start
- 95 GSR intake manifold.
- oil leaking. please help
- How much resistance from a Honda resistor box?
- '99 USDM B16A2 in '96 CX wiring issues
- b16 in 4door teg
- B16 engine build questions
- How do i hook up a 3 bar GM MAP to the ecu? pics inside
- 6500 rev limiter RPM cutoff problem on a boosted B18C1
- Do you Know F20B6 accord ´99???
- distributor wiring help
- Skunk2 or Crower
- Advice
- VTEC not working!
- can you trace the history of a motor w/ the block #?
- how to change a head gasket?
- Single vs Dual Stage Airbag
- Nitrous Help Needed !
- Nitrous Questions and Help PLease(all hail to the god of car the king himself Mr NSX)
- Sneaky Ice Systems
- Cam gear tuning
- d17a2 swap into my 93 hatchback??
- wiring is killing me please help
- MAP sensor 98 Civic
- leaking header gasket change exhaust sound?
- New Setup
- Can anyone PLEASE HELP!!!!
- h22 ob question
- Hard to start
- Cheap Speed
- B16A swap in 95 civic...no start
- dark brownish head
- DOHC ZC Code 4-20 cutting at 3200 RPM running on PG7 HELP!
- b20 in 1994 LS integra????
- 98 Cl 2.3
- soon to go crazy
- b18a1 build questions
- R/S question in ls/vtec conversion and other ?
- A Problem with Map sensor
- need answers
- Opinion?
- N/A setup...hows it sound?
- what ecu wiring color to connect vtec
- shift linkage length ?
- 92 Vigor- got ABS code 1-2 -(Pump Motor Circuit)or Motor Relay fuse???
- Lightened Flywheel
- EK9 Pistons im my B16a2??
- Rods don't fit
- gsr rod knock
- what gas should i use
- will a 91 2.1 litre motor go into a 92 prelude and what will i have to change
- Oil in my front mount intercooler????
- why swaps of coarse........
- does anyone here have a hondata or a aem management system
- H23 Swap Help!!! H-series Related
- OBD 2 to OBD 1
- how much does the seconday o2 matter???
- **** Engine Problem **** HELP !!!!!!!!
- cat converter? header? headache!!!
- Integra won't start after new clutch
- short ram intake
- b18cr in a DA problem
- How do I pick the right internals?
- spun bearing
- Cant get Acura to start...
- Down Pipe anyone?
- Help! 5th Gen Accord Mod choices, Which ones?
- dc header without o2 sensor
- JDM H22a firing order?
- nitrous
- Transaxle fluid on a 5spd?
- honing my block
- oil leak around drainage plug and tank
- vtec killer cams ?
- gsr in a 97 2.2 cl?
- oil seperator can plug
- swap motor doesn't start
- first mod for my car
- MOBIL 1 EP motor oil
- Pressure Tester of some sort?
- B18C1 swap with B18C type R
- Please.. lets try this again
- spark problems.......
- HELP........... for my 2005 RSX
- the boosted civic is broken fo sho
- civic apexi svafc
- TypeR clutch & fly in LS
- anything worth doing to an 06' Accord SE sedan w/iVTEC 4-cyl?
- b16 help?
- B16 Engine Breakdrown
- another ctr/gsr thread
- best set up for a b16a
- holy shit i hate wirring (h22 civic map sencor)
- help with IAB(secondary runners) on B18c1 swapped civic!!
- turbo help
- slipping tranny ?
- B20 Boosted??????????
- somewhat newbie needs info on b16a2
- my 96 civic vtec swaping
- Comments on what to do to teg?
- 96 Civic ex vtec
- its a sad day for the boosted civic in florida
- calibrate t.p.s sensor honda accord
- Will an exhaust leak make your motor run rich?
- Motor sitting for months with no use???
- s3 problem
- leaning twoards boosted b16b
- MAP sensor
- b18b idle pronlem? HELP
- whos running a standalone ecu????
- K20 swap into dc2
- 96' civic LX need new engine
- HELP!! ZC dizzy
- K&N Filters
- just finished b18b swap in my 92 hatch. questions????
- does anyone know
- Better tuning potential 2003+ RSX Type-S or Integra GSR
- HELP, odd idle after engine warm up
- Help!
- AEM hybrid intake
- Best Engine for Turbo???
- How do I make my botom end stronger?
- b18b internals in b18a and lots of ? [for EG Civic swap]
- How good is this turbo kit?
- 90-93 LS integra throttle cable for 1995 LS in civic
- gsr s80 starter???? HELP ME!!!!!!!!!!!!! [EG Civic/ B18B]
- tranny swap
- CRX Swap
- F22 Motor in HB?
- b18c gsr engine trouble
- Code 1166 & 1167 -- 1999 Accord LX
- prevent leaking head
- What should I do?????? Fix the vtec head I have or get another one
- need to pick someone's brain [GSR motor into DA9]
- Ty on motor info
- Can I Use A Supra Or A Prelude Motor In My 90 Teg
- Honda/Acura labeled timing belt and waterpump....... difference?
- 2000 Honda Civic Si Owner Needs advice............................................ .
- Dizzy?
- code P1166
- new at this
- new at this
- OBD2 Question.
- OBD2 O2 sensor
- ZC ecu upgrade ?'s
- Help!!! Car Died!!!
- quick question about bseries
- Performance chips/module question
- 300whp b18b1
- Ls/Vtec or GSR engine
- Problem with Spark
- b18c1 and k20a weight difference
- burns oil
- what are some good way to make 270 hp in 1998 hatch
- what civic vtec motor can go in a teg
- Buying B-Series Turbonetics Turbo Kit
- Whats the easiest auto-Manual swap engine for my 95 ex coupe?
- type r swap
- will gsr cam shafts work for my b18c5?
- Supersprint headers??
- h22 civic tps problem ??? help!!!!!!!!!!
- JRSC MAP Sensor Help
- Honda/Acura Fuel Pump Questions....
- Honda/Acura proformance shop on LI NY
- engine noise
- #4 cylinder not firing on D15B2?
- B16A1 problem
- ATF-Z1 transmission fluid
- place for '04 RL questions?
- third and fifth gears grinding
- b16a in 95 teg rs
- 1999 Gsr Swap
- DC2or DA6
- Engine Swaping (B18C into 91 Integra LS)
- 86 civic engine
- Turbo problems
- Maint Required light
- CEL Code 8: TDC
- Crower cams?
- Radiator fan
- 94 Civic EX w/ B16A2 swap?
- Obd2a To Obd1 Automatic Trans.....ecu Conversion...help
- will this fit
- 87 Accord Auto --> Stick
