b16a2 vs. b18c1 vs. ???
Old Nov 9, 2005 | 08:41 PM
mikey_e69's Avatar
mikey_e69
Default b16a2 vs. b18c1 vs. ???
i have about 3000 dollars to work with and i was wondering what the downfalls to each of these swaps would be. also what is everyones personal preference??? im sooo open to suggestions whether it be all motor, or turbo, etc but keep in mind i do have a budget. so basically if u were me and u wanted a swap what would it be and why!!!
Old Nov 9, 2005 | 09:35 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
i would go with a b16a2 and boost it. b18c1 you will spend atleast $3000 on the swap if not more. with a b16a2 you will have room to play once you get it installed.
EDIT:
Although a b18c1 is well worth the investment, a jdm b16a2 is a wopping 15 hp less, and that ground can be made up real fast.
Old Nov 10, 2005 | 04:29 AM
mikey_e69's Avatar
mikey_e69
EDIT:
thanks brother. any other suggestions??? how much does LSD really help? how much can i expect to pay for a FULL b16a2 or b18c1 swap???
Old Nov 10, 2005 | 06:10 AM
teg92's Avatar
teg92
WHAT OK YEAH!
b16a2 full swap will probally cost about $2200.00 and a b18c1 about $3000.00 and LSD will be an additional $300.00
Old Nov 10, 2005 | 10:46 AM
97civicEXVTEC's Avatar
97civicEXVTEC
the big differences between the b16a an the b18c1 is the torque and cost..
imo b16a2>b18c1
Old Nov 10, 2005 | 11:27 AM
mikey_e69's Avatar
mikey_e69
starting to lean toward the b16a2. i guess it would be more cost effective and i still need to buy a donor car!!! what would be the best way to start an all-motor b16a2 setup?
Old Nov 10, 2005 | 12:14 PM
if ur looking to go quick... B18B, save up a little and piece together a turbo setup... B18C1 if u want to go all motor.... honestly i dont think the B16 is worth the money you dump into it unless u have it...
but then again unless u just want the vtac... go for b16A its cheaper but i doubt itll be any faster than what you have now....
Old Nov 10, 2005 | 06:45 PM
hitman619's Avatar
hitman619
SDSU Basketball
id go with a ls motor it will be cheap and if you want vtec just put a b181c1 head on there........ ls/vtec
Old Nov 10, 2005 | 07:13 PM
mikey_e69's Avatar
mikey_e69
well also keep in mind that this will be a DIY swap too!!! ls/vtec is kinda outta the question unless i can aquire parts and get it built for under 3 grand
Old Nov 10, 2005 | 07:36 PM
b16ahybrid's Avatar
b16ahybrid
If your going with turbo get either the b16a or b18b (cheaper and both make great power with boost)
If your going to keep it N/A then by all means get the b18c. The b18b and b16a are not the best choices for all motor (since you did menton that ls/vtec was out of the question).
If your undecided about asperation then go with the b18b. If you go n/a you can add a b18c head and make good power and if you go with turbo you'll make even better power.
the b16a is good ONLY if your boosting (IMO)....LSD is worth every penny.
