prevent leaking head
Old Sep 25, 2005 | 01:55 PM
EkcivicBeast's Avatar
EkcivicBeast
Default prevent leaking head
do you think it's wise to use silicone to aid in sealing the head properly to prevent leaks?
Old Sep 25, 2005 | 03:31 PM
qtiger's Avatar
qtiger
If your head isn't seating properly against the block then you have problems that need to be fixed.
Old Sep 26, 2005 | 09:18 AM
EkcivicBeast
im srry,i don't think i phrased it properly, i am putting together a motor, and i want it to be a reliable build,one of my concerns where making sure everything is sealed properly,i ask because i see cars with new head gaskets n new built motors with leaks in the head.my thing is that i have had my block in head resurfaced even, and i was wondering would that be enough to just seal the head properly??? thanks
Old Sep 28, 2005 | 12:37 PM
1995Civic's Avatar
1995Civic
I hate ricers
OEM headgasket w/ ARP headstuds and you should be fine
Old Sep 29, 2005 | 08:17 AM
Snoopy's Avatar
Snoopy
been there done that
use an oem headgasket and torque everything down to specs in the proper order.
