GSR swap
Old Nov 1, 2005 | 04:34 PM
EK9er's Avatar
EK9er
John 1:29
Default GSR swap
Can anyone help me out, when you swap a GSR into a car w/ single cam vtec, what engine harness do you use ? Or can you modify the original harness to work with the different plugs that are on the GSR...
Thanx for your input
Old Nov 3, 2005 | 11:20 AM
b16ahybrid's Avatar
b16ahybrid
Use the b18c engine harness the plugs are the same unless your swapping a 0bd-1 into a obd-2 or vise versa.
Old Nov 8, 2005 | 12:41 PM
Phateless's Avatar
Phateless
S2K compatible
yeah sounds like you're mixing engine management. what year motor and what year car?
Old Nov 9, 2005 | 02:11 PM
EK9er's Avatar
EK9er
John 1:29
97 GSR into a 2000 civic
Old Nov 9, 2005 | 02:17 PM
boriblanco's Avatar
boriblanco
they are both obd2 so they plug into each other but i think you need to run the knock sensor, and the flaps.
