Code 1166 & 1167 -- 1999 Accord LX
Old Sep 25, 2005 | 07:24 PM
ubmc1964's Avatar
ubmc1964
Default Code 1166 & 1167 -- 1999 Accord LX
I have a 1999 Accord LX w/ 4 cyl. ULEV engine, auto trans. Recently CEL lit up, wife took it to dealer while I was out of town. Dealer diagnosed code 1166 and said after cat. oxygen sensor needed to be replaced. I bought a Bosch 13071 sensor and an OBD2 reader. Installed the sensor and cleared the code with the OBD2 reader. Started engine and within 30 seconds get codes 1166 and 1167? Any suugestions? Could the replacement sensor be bad or non-compatible? It seems more like a wiring problem, please tell me where to look.
Old Dec 27, 2006 | 01:46 PM
art weaver's Avatar
art weaver
Default What Was The Result Of 1167
What Was Problem 1167
Old Dec 27, 2006 | 03:50 PM
htech1982's Avatar
htech1982
Default heated o2 sensor problem
if the boush sensor did not fix it you may want to try a honda one. although you could have a bad ecm. substitute for a known good one and see what happens. did your scanner say it was sensor one or two?
