'99 USDM B16A2 in '96 CX wiring issues
Old Oct 23, 2005 | 05:20 PM
nblanton's Avatar
nblanton
Default '99 USDM B16A2 in '96 CX wiring issues
I just swapped in 99 Si B16A2 into my 96 CX hatch. It runs, but I don't have an A plug to go with the engine harness. Are there any quick fixes for this, or am I going to have to just cut the on off my old motor and rig it up? Right now I don't have any speedo, vtec, and I'm throwing codes for the canister purge valve and the gas tank pressure sensor.
Old Oct 23, 2005 | 05:28 PM
teg92's Avatar
teg92
WHAT OK YEAH!
its probally beacause you have and OBD2b engine in an OBD2a car. What harness are you using?
Old Oct 23, 2005 | 05:31 PM
nblanton's Avatar
nblanton
I'm using the harness that came with the 99 B16A2.
Old Oct 23, 2005 | 05:34 PM
teg92's Avatar
teg92
WHAT OK YEAH!
and your using the b16a2 ECU right?
Old Oct 23, 2005 | 05:38 PM
nblanton's Avatar
nblanton
Yeah, I've got everything from the 99 Si in the car, except the stuff that plugs into the A plug
Old Oct 23, 2005 | 05:44 PM
teg92's Avatar
teg92
WHAT OK YEAH!
hmmm you should try using and EX harness froma 96-98 civic
Old Oct 23, 2005 | 05:57 PM
nblanton's Avatar
nblanton
According to my helm manual(which is a POS PDF version that I got on eBay) the 96-98 pinout is the same
