how to change a head gasket?
Old Oct 20, 2005 | 12:53 PM
TM1520's Avatar
TM1520
Default how to change a head gasket?
i'm changing my zc's head gasket, i took the head off, got the new gasket. after putting the head back on, do i have to do anything else like timing the cam gears if so how?
Old Oct 20, 2005 | 02:17 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Well, the timing belt has to be put back on exactly how it was taken off. You need to align the crank at TDC and then line the belt up on the cam gears.
Did you make sure to torque the head bolts to spec in a crosswise pattern?
Old Oct 21, 2005 | 03:34 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
yeah, i'd make sure you torque everything down to spec.
Old Oct 22, 2005 | 12:00 PM
TM1520's Avatar
TM1520
what do you by spec? i forgot how i took the the belt off.
Old Oct 22, 2005 | 01:08 PM
1995Civic's Avatar
1995Civic
I hate ricers
By 'Spec' he means by Honda factory OEM specification. Make sure they are torqued down to what Honda recommends them to be at.
Old Oct 24, 2005 | 12:14 PM
TM1520's Avatar
TM1520
does anybody know where i can find the specs?
