third and fifth gears grinding
Old Sep 18, 2005 | 09:53 AM
boznuttz's Avatar
boznuttz
b 16 integra
Default third and fifth gears grinding
im really new to this. i have no problem starting off, but the transition from second to third come at over 7000 rpm, the gears scratch before it catches ( same thign happens as i put it into fifth at high revs too). i cringe whenever i hear it, even when i drop it into third from 65. my brother says it may be the gearbox but im not too sure. what problems am i lookign at?
Old Sep 18, 2005 | 10:04 AM
b16ahybrid's Avatar
b16ahybrid
syncro's.
Try changing your tranny fluid with honda MTF and give that a shot. The last owner may have used some cheap fluid.
I know when I changed my tranny fluid to redline it caused my gears to grind (don't recall what gears as it was a long time ago) because it lubricates so well. I changed back to honda mtf and solved the problem.
Old Sep 18, 2005 | 09:39 PM
boznuttz's Avatar
boznuttz
b 16 integra
thanks man, ill try doin a full fluid swap and if it doesnt work (sigh), new gear box
Old Oct 15, 2005 | 10:14 PM
HcOiNvDiAc's Avatar
HcOiNvDiAc
GOT HONDA?
my 3rd is gone too ....just incase though i drained and refilled my tranny fluid to see if it would help any ....nada
Old Oct 17, 2005 | 09:00 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
honda mtf is the best!
