Can anyone PLEASE HELP!!!!
Old Oct 16, 2005 | 04:15 PM
EK9er's Avatar
EK9er
John 1:29
Default Can anyone PLEASE HELP!!!!
The deal is, my 2000 si was ripped from my heart by thieves, dirty thieves, and they took a bunch of crap off the car, I just got it, only had 'er 3 days, anywho, the main items they took were my head and engine harness. So in lies my problem, see I have a spare gsr head chillin in my garage but before I use it I was wondering if a gsr engine harness will plug into the si wiring. If anyone can help I would greatly appreciate it
spanx
Old Oct 17, 2005 | 08:58 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
i would imagine so, as long as its and obd2 harness like the stock 2000 si harness. That car is famous for shit like that happening! I feel you pain, happened to a friend of mine, be glad you still have the block and tranny!
Old Oct 17, 2005 | 10:05 AM
teg92's Avatar
teg92
WHAT OK YEAH!
ya like jdmeg6 said as long as its OBD2, you could also use a harness from an 99-00 civic EX to if you wanted too
Old Oct 18, 2005 | 02:53 PM
EK9er's Avatar
EK9er
John 1:29
Good lookin out guys, I really appreciate it, I had the same question on clubhonda.com posted going on three weeks and no one has replyed yet so its a big help thanks
Old Oct 18, 2005 | 03:05 PM
teg92's Avatar
teg92
WHAT OK YEAH!
No problem good luck
Old Oct 18, 2005 | 09:50 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
NO! The GS-R harness will not work for you. The '96+ Civic chassis (common called EK's) use a single harness that runs through the firewall down to the ECU. The '92-'95 Civic's (EG's) and '94+ Integra's (DC's) use a 2 piece harness which has one connected to the engine and another that connects to that harness at the shock towers and then runs to the ECU. You must use an EK harness in an EK car. There are also 2 versions OBD IIa and OBD IIb ('96-98 and '99-'00 respectively). If your planning to plug into your '99's stock ECU, you will need an OBD IIb harness. You can use any '99-'00 Civic harness, but the lower models will need additional wires run for missing features not on the old D-series engine.
Old Oct 19, 2005 | 12:04 PM
EK9er's Avatar
EK9er
John 1:29
Cause Ive tried a gsr head w/ si wiring some of the wiring wont plug in right, so your telling me I can only use one or the other, si head w/ si harness or gsr head but I would have to run all gsr wiring??CRAP!!
Old Oct 20, 2005 | 11:37 AM
egghead's Avatar
egghead
TF Plasti-crack Crew
I think you should be able to swap some gsr plugs onto the si harness for the ones that don't plug in right. There might be some other stuff you have to do to make it work right, but I'm not positive. The gsr wiring harness definitely won't work though because of what the others said.
