no fuel through injectors
Old Oct 27, 2005 | 04:27 PM
contentious's Avatar
contentious
Default no fuel through injectors
I just took my obd0 b16a (motor only) and put it in a 93 del sol. I changed everything over to obd1. it cranks and I am getting spark, also I am getting fuel to the intake manifold. but it won't fire. I tested my main relay (it was good) and replaced the blown #18 fuse. what else could there be?
Old Oct 27, 2005 | 04:38 PM
b16ahybrid's Avatar
b16ahybrid
Did you change the injectors? I believe the non-obd motor has peak hold injectors and your car (obd-1) uses saturated injectors. If that the case you can just pick up a resistor pack and wire that in.
