which head can get more hp
Old Oct 29, 2005 | 07:11 PM
civichatch977's Avatar
civichatch977
Default which head can get more hp
which head can achieve more hp the dohc zc head or a sohc y8 head
i have both and plan on doing a all motor build up but some say the y8 head is better and some say the zc
so which is it
the head will be sitting on a y8 block and internal stroked to a 1.9 liter
Old Oct 29, 2005 | 07:52 PM
jlicrx's Avatar
jlicrx
DOHC ZC head will not work on SOHC block
Old Oct 29, 2005 | 09:25 PM
civichatch977
i saw that you can
http://www.honda-tech.com/zerothread?id=1079426&page=1
i got the idea from this site
Old Oct 30, 2005 | 03:53 AM
1995Civic's Avatar
1995Civic
I hate ricers
so which is it
Well, the DOHC ZC head is non vtec, while the SOHC Y8 is vtec. Not that it really has anything to do with it, because you can make anything fast with time and money (a lot of it in some cases)
Also, you can't really ask people 'which head will create more hp' There's many different things that cause the numbers to go up. You going FI or NA?
Old Oct 30, 2005 | 10:05 AM
qtiger's Avatar
qtiger
i saw that you can
Read the thread. The head and the block don't quite line up... coolant passages specifically... and it leaks coolant between the head and block.
I would highly advise against doing this swap.
Old Oct 30, 2005 | 11:30 AM
1995Civic's Avatar
1995Civic
I hate ricers
Yea me too.
Coolant passages do not line up, and leak. You also have to do some modification to the head gasket and definitely change out your headstuds. All this "just to be different?" Sorry but not at all worth my time and/or money.
Old Oct 30, 2005 | 06:01 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I agree. Using that guy's nasty setup as inspiration is foolish. You can tell just by the pics that it is leaking coolant badly from in between the head and block.
Why not just swap the motor out completely? A D-series N/A motor isn't really worth the money, IMO. I have seen great numbers out of fully built D-series, but that included a ton of R&D and money.
Old Oct 30, 2005 | 06:24 PM
qtiger's Avatar
qtiger
Beyond that, I don't understand why someone would go through all that work to frankenstein on a crappy head from the late 80s just to have DOHC.
I'll bet a late model D series VTEC head flows infinitely better than that beast. I don't think the tunability of DOHC is worth the sacrifices being made in using that head.
