MOBIL 1 EP motor oil
Old Oct 4, 2005 | 08:58 PM
Robstunner's Avatar
Robstunner
y0! Vito!
Default MOBIL 1 EP motor oil
So Im looking to change my oil at autozone. i go to the oil spot and pick up my usualy Mobil 1 ful syn motor oil. then i look to the left, and i see mobil 1 super synthectic (fully synthetic) motor oil guarenteed for 15,000 miles or 1 year, (whichever comes first. does anyone have anything to say about this oil? I have a 2001 GSR and it runs great, from the sound of it the oil should be good, and mobil 1 is the best oil out there, but 15,000 miles? anyone using this? any suggestions? LMK
Im using a Honda OEM filter with a brand new oil drain bolt (=)) and new crush washer.
thanks
Rob
BTW:
Heres some info on the oil:
Mobil 1 Extended Performance 5W-30 meets the following industry approvals:
* ACEA A1/A5, B1/B5
* API SL
* It also meets the requirements for diesel powered vehicles where an API CF or CD oil is recommended.
All Mobil 1 Extended Performance viscosity grades have been tested to be fully compatible with engine seals and conventional oils. A special oil filter is not required.
Mobil 1 Extended Performance motor oil is designed for today's longer service intervals. Mobil 1 Extended Performance products contain 50 percent more SuperSyn, 37 percent more cleaning agents, and 36 percent more anti-wear additives than Mobil 1. Mobil 1 Extended Performance with the Advanced SuperSyn System helps keep engines running like new and helps extend engine life by reducing wear and oil breakdown. Please follow the recommendations in your owner's manual while your car is under warranty.
Old Oct 5, 2005 | 09:18 AM
Robstunner's Avatar
Robstunner
y0! Vito!
hmmmm...
bump?
Old Oct 5, 2005 | 10:17 AM
sherwood's Avatar
sherwood
I missed Sean
ask for it to be moved to the basment.. it's general enough and that area gets massive ammount of flow
