B18B vs B18B1
Old Oct 24, 2005 | 07:28 PM
Tellurium132's Avatar
Tellurium132
I fail at life.
Default B18B vs B18B1
Are there any other things different between these two engines besides what looks like different designed valve covers and engine designation codes.
If i recall, B18B1 is USDM and B18B JDM. They should technically be the same engine right (internal wise)?
What makes a JDM better than a USDM version concerning these two engines ?
Old Oct 24, 2005 | 08:02 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
jdm b18b's compression is higher by .2 (9.4 compression, usdm is 9.2). As a result, the jdm motor produces 3 more horsepower.
Old Oct 25, 2005 | 05:26 PM
raiden571's Avatar
raiden571
turning u inside out
i wasnt aware there was a difference. tho, jdm engines typically have a lil high compresion, but who knows. internally, if anything is different its either the head is ground more, or the pistons yield slightly more compression
Old Oct 26, 2005 | 06:08 AM
jeterkm02's Avatar
jeterkm02
i didnt want to post this earlier because im not 100% sure of what its called, but the jdm motor doesnt have that black emissions box located under usdm intake manifolds.
Old Oct 27, 2005 | 02:30 PM
speedfreak0920's Avatar
speedfreak0920
cArz...gUrls...m0re caRzt
jdm b18b's rev a little higher and make a little bit more hp and tq. and yes their compression is raised. i had a jdm b18b with 40k and it ripped like a b16.ran a 14.6 in my eg
