Fine tune A/F?
Old Nov 4, 2005 | 03:18 AM
psx_pat's Avatar
psx_pat
Default Fine tune A/F?
I have b16head/b20 block with i/h/e and everything else is stock. It's a OBD-0 PR3 ECU. Do you guys thing if I fine tune the air/fuel ratio (with Hondata,VAFC,etc) will I get noticeable different in performance? Or it's not worth it and leave it stock ECU? Thanks.
Old Nov 4, 2005 | 04:43 AM
shivers's Avatar
shivers
Moderator Alumni
Tuning the a/f to a proper ratio will net you more power. Having a tuned car is always a bonus in my book and definitely worth it.
2005 s2000
Old Nov 4, 2005 | 01:58 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
Deffinatly more reliable tuned.
Old Nov 4, 2005 | 02:40 PM
Kai's Avatar
Kai
Rotorphile.
The computer you're running thinks it's feeding a 1.6l engine, when it's really feeding a 2.0l engine... not good. You need something to correct for this, the stock computer can only do so much to richen the mixture.
Old Nov 4, 2005 | 03:15 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
AFR all motor 12.9 -13.1 any lower is too rich any higher is too lean.
And reguardless of what the people say who have never tuned in their life, it will be a night and day difference depending on how you tune it.. make sure to mess with every part of the map u can, low and high cam, and the igiton.. as well.. before u do any tuning tho make sure ur timing belt is good, and ur timing is on mark, with ur dizzy set at 16 or 18 degrees..
Old Nov 4, 2005 | 06:35 PM
psx_pat's Avatar
psx_pat
Thanks for the opinion. Right now I adjusted my fuel pressure based on sparkplugs condition. Is this good? And I'm thinking just to get VAFC2 and AEM UEGO wideband a/f ratio to tune it with. Is it good enough?
