View Full Version : Integra & '97-'01 Integra Type-R
  1. Horn broken!!!??!
  2. Moon roof is slow?
  3. diffrence between b18a nad B??
  4. 4 door integra ok??
  5. What level of tint?
  6. Problems after DIY 90k service, please help
  7. DC2 JDM type r conversion on my teg need help!
  8. header questions
  9. Suspension Issue
  10. Dashboard won't light up
  11. Anyone know of or would like to start a group buy for painted sideskirts?
  12. Lower springs/alingment
  13. Which tires to buy 195 55 15??
  14. turbo kits acessories
  15. gsr head
  16. does jdn gsr come with oil pressure switch
  17. b16 tranny knocking
  18. I'm blowing out a Suspension Techniques Sway Bar Tie Bar combo SPEEDTECH
  19. 98 teg engine swap!
  20. 1994 LS with 2001 ITR front end. pix!
  21. need carfax
  22. Dashboard blower motor question
  23. i just bought a jdm gsr and i dont know how to wire vtec
  24. Help me pick out a new radiator.
  25. Quiet Exhaust.
  26. Recommendations for exhaust/suspension...
  27. bad coilovers?
  28. strange problem
  29. GSR Owners
  30. 1993 acura gsr horsepower
  31. Eibach Struts
  32. 2000 front bumper cover...
  33. Timing Belt Change Notification Othen Than Miles or Too Late
  34. 4dr Exhaust
  35. Shifting problems
  36. CEL code 22
  37. Header Question
  38. The timing belt on my GSR snapped today
  39. just one
  40. bouncing tach and rough running after dropping in new engine. please help!
  41. o2 sensor(s) on an OBD1 teggy
  42. OK, thinking of diving in, where to start with mods??
  43. OK, thinking of diving in, where to start with mods??
  44. I need an IAT Sensor
  45. Haynes manual help
  46. Tranny noises
  47. wheels question...
  48. advice on turbo n exhaust...
  49. Hi, I'm new and would like some general info..
  50. this is what happens when you are retarded
  51. brakes?
  52. 90 integra ecu Q
  53. Anyone been to this place? (so cal)
  54. Strut-tech
  55. B18 cylinder warped?
  56. Skunk2 Weighted Knob Question
  57. wow
  58. 3rd gen integra backseats roomy?
  59. injector problem with integra
  60. "muffler"
  61. Somethings Wrong!
  62. what im told is ecm problem,please advise
  63. best place to buy tail lights?
  64. squealing steer
  65. Vibration/steering problem
  66. Type R (Engine & Turbo ??)
  67. Direct-Fit Cats
  68. electrical problem!!!! relay possibly?
  69. ECU-ish
  70. RSR *Japan Dealers in Canada???
  71. what is a N/A b18b motor?
  72. what should i pay for this gsr
  73. help changing motor from 88RS to 87 LS
  74. <> DO NOT post "For Sale" items in this forum!
  75. rear end making a loud humming noise as i drive...
  76. Will a 95 Ls attract thieves?
  77. will an rsx steering wheel fit???
  78. will rsx seats fit????
  79. wheel bearing causing weird clicking sound???
  80. Need Help
  81. Are you ready for the ITR EXPO 6 ???
  82. 0- 400m
  83. Will GSR Rails work for JDM Recaros?
  84. B18c6
  85. performance injectors??
  86. Autocross integra
  87. Weird Problem
  88. passenger side door/window malfunction
  89. 99 GSR Shift Linkage Very Sloppy Please Help!
  90. find an engine
  91. weaird speaking
  92. auto tranny question
  93. Anyone From Nj/ny Area With 2nd Gen Parts!!!!!!!!1
  94. anyway to clean headlight lenses?
  95. Basic Questions about suspension
  96. Pics: JDM ITR restoration
  97. Pics: JDM ITR restoration
  98. Throttle body
  99. help i cant think
  100. 96 gsr clutch squeeks!
  101. Whats the best way to upgrade?
  102. doing jdm convo on g2!!!
  103. Want To Go With New Dunlop FM901's...?
  104. Suspension Job #3. Hopefully the last one.
  105. steering rack replacement, need help.
  106. Red gauge dash lights?
  107. my ls is acting like a gsr
  108. turbo or vortex
  109. Noob question
  110. cold air intake
  111. need a ls motor and tranny
  112. Auto to manual tranny in 99 LS?
  113. V-tech a normal DOHC
  114. wheel bearing question between da+dc teg's
  115. spoon valve cover???
  116. Best Place to Buy New Parts
  117. no vtec in 4th gear..what???
  118. reseat valves or lapping?
  119. leaking antifreeze
  120. G3 Antenna
  121. Turbo Kit Ideas?
  122. anyone try dash trim kits?
  123. new stereo, but now no interior lights
  124. V-tec problems after mods
  125. what is the best sri out right now for the gsr?
  126. Need Help
  127. Transmission fluid
  128. 4th gear at 8500
  129. 94 integra DOHC non-vtec
  130. What cams are these?
  131. tuff decision
  132. Firing Order For 94 Integra Ls?
  133. messed up rotor / caliper - need help
  134. Rack and pinion HELP!!!!!!!
  135. Integra engine died for no reason
  136. Subframe Tearout
  137. 2001 vs 2000 and earlier radiator differences.
  138. Increading the height of a lowered car
  139. Im hooked on BOOST
  140. b18c1 g2 swap
  141. Are 94-00 Integra 2dr Axleback Exhaust Interchangeable With 95 4dr Gsr.. Please Help.
  142. my turbo parts, whats missing?
  143. 2nd Gen Mounts
  144. Question about Compression Test
  145. A arms
  146. 92-95 civic lower passenger tranny mount fit integra?
  147. what seats are you usin??
  148. Maintenace Light Please Help
  149. this is for u Valve Guru's
  150. i have a gsr problem....
  151. Type R Trans
  152. silencer stuck
  153. Shifting RPMS
  154. Aftermarket pedal help
  155. Shfit problem for 94 Teg Auto
  156. torque converter
  157. Did I get screwed? thepartsbin.com
  158. JDM lights help!
  159. JDM b18c Transplant...
  160. NE1 happy w/ thier "fake/cheap" header??
  161. RPM gauge is dead.. HELP
  162. airbag question, need help.
  163. ls vs. gsr
  164. Seemed like a Stall then Restart all by herself
  165. Hondata and Crome Question
  166. Quick question for integra exhaust/performance
  167. quick question about rear brakes
  168. 97-01 prelude seats in a 94-01 teg
  169. What is a good kind of tire for my '00 Integra?
  170. 96 int starting problems
  171. video of my GSR gauge during vtec
  172. convertion
  173. swap install pricing......?
  174. stroke
  175. window tinting advice
  176. Oil lines? T or sandwich?
  177. The car shakes when shifting
  178. b20b fuel cut
  179. exedy clutches and flywheel.........
  180. Front end sits to high??
  181. Need to see the light .
  182. Advice on a car?
  183. I need Struts
  184. kyb-gr2 struts suck!
  185. Inline 4 Crew Pics !!!
  186. Will my struts off my 99 GSR fit my bro's 96 RS?
  187. 94 GSR exhaust sputtering w/ no low end power
  188. 93 Gsr Intake????
  189. Clutch SQUEALS! Help
  190. my auto door won't open from inside
  191. Q: headlamp replacements - any good??
  192. Q: anybody have problems with wheel alignment?
  193. Q: Tan leather interiors on different years?
  194. Bad injectors?
  195. Need advice on Integra?!
  196. buying used teg, what to look out for?
  197. Whats this guy talking about?
  198. cylinder missfire
  199. mount insert or glue for a customer
  200. 4 choices, which would you choose?
  201. Is my exhaust too big
  202. exhaust for fourdoor gsr
  203. New whip
  204. clutch can i get some opnions from the guys at HAN
  205. Replacing radiator - need clarification on block flush
  206. car hesitates after warmed up in winter or cold weather
  207. When doing a compression test...
  208. CEL Light not blinking
  209. Trans swap: From 87 Civic CA4 to 87 Integra CA4 Trans
  210. transmission problems
  211. broken ignition
  212. Radiator doesn't draw back from reserve
  213. how much should I lower to equal...
  214. reat strut flang bolt
  215. New sh*t on the block...soon
  216. invidia exhaust on 95 teg gsr?.....
  217. fuel system cleaner.
  218. Low Torque on Integras?
  219. Putting money into a 96 GSR
  220. Who makes the best Cat converter?
  221. hazy headlamps
  222. Need A Rear Fender!!!
  223. Need help, is the repairs worth it?
  224. How much room?
  225. 96 rs using hi octane
  226. 17" Gram Lights 57c
  227. Question about 90,000 mile service
  228. Ignition rotor and coil screws stripped..what to do?
  229. Integra Horn
  230. STOLEN Black GSR - Long Beach, CA
  231. 1995 Integra SE, 77k miles value?
  232. 1999 Integra Auto Transmission problems...
  233. Short Shifter Question
  234. For anyone using a prostreetonline.com timing belt kit
  235. considering boost
  236. brake light won't turn off
  237. 3200rpm engine vibration / resonance ?
  238. popping noise..ball joint or axle?
  239. Something missing here?
  240. Thinking of buying an Integra..
  241. Need Help, Type-R all motor or all boost
  242. vtec issues...
  243. jr supercharger question for 94 integra
  244. Integra race car
  245. axle help
  246. gas needle slower than normal? :S
  247. Car wont start
  248. Engine knock or Injector noise or what?
  249. Tein civic (EF) springs on my 91 Teg w/oem struts? *searched*
  250. Ls/Vtec Question
go
Search Engine Friendly URLs by vBSEO 3.5.2
