compression
Old Jun 21, 2006 | 03:38 PM
gsr converters's Avatar
gsr converters
Default compression
what kind of compression is to much for pump gas in a b18c1, also will how high could you go before everyday driving was compromised, if fully built
Old Jun 21, 2006 | 05:29 PM
dubcac's Avatar
dubcac
I
I wouldn't go over 11.0:1 or so without a tunable ECU like hondata/etc. I've seen 12:1 run on pump gas with hondata...but a lot of timing was pulled out. I had a friend running 13:1 on the street, and he had to mix 2 gallons of Toluene with each tank of gas...and he was running a J&S Safeguard.
Old Jun 22, 2006 | 03:23 PM
gsr converters
thanks, getting ready for some new pistons, and a lot of other goodies, looking to build up a mild na engine for my car, any suggestions would be appreciated
Old Jun 22, 2006 | 03:31 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Toluene? Good lord! Don't they use that in TNT? Yes they do, Tri-nitro-toluene
Old Jun 22, 2006 | 03:52 PM
Nors's Avatar
Nors
倍力恋
well, toulene does origanlly come from making gasoline. But yes, also used in TNT I think.
Old Jun 22, 2006 | 10:24 PM
dubcac's Avatar
dubcac
I
That's the stuff. Raises octane quite well.
Old Jun 23, 2006 | 04:00 PM
gsr converters
how would 11:1 be, in a built motor,acceleration and what not, and horse power, building the entire thing, just looking into diff ways of going about this
Old Jun 23, 2006 | 09:46 PM
dubcac's Avatar
dubcac
I
Obviously more compression is going to make more power, but 11:1 is a good street compression. The USDM Type R motor has 11:1 compression.
Old Jun 24, 2006 | 12:28 PM
gsr converters
well ive been looking at a crower stroker kit to turn it into a 2.1 liter, with some higher compression and some cams and other things, i think i would have a bad ass motor, just looking for some opinions thanks
Old Jun 24, 2006 | 08:36 PM
dubcac's Avatar
dubcac
I
Stroker kits suck and ruin the revvability of the motor. If you want to increase displacement, get your block sleeved and bore to 84-85mm...which will make it about a 2 liter, and you'll keep the revvability.
