Dashboard blower motor question
Last night driving home I lost use of the two lowest speeds on the fan control. Turn it to the bottom two speeds and no go...top two work, but it sounds like a vibration of some kind (kind of bassy and rapid). I was thinking about yanking the blower motor to put in a new one.
Any suggestions on the problem, fix procedures, or other problem it might be?
PS...I'm new here and need all the help I can get.
easy fix. it is your "resistor block" block of two(?) resistors behind the glove box that control the current for each setting. each setting uses a different combo of the resistors to set the current. lose one of the resistors and some of the speeds won't work. It is a little box about 2" across with a big 4 or 5 wire plug going into it. Unplug and if your fan no longer works at all, you have found it. Your blower motor should be fine. Not really sure where the best place to get a new one would be.
edit* just noticed you got a 91 and everything i was said was for a 94+, should be a similar layout though.
Originally Posted by 91-teg
Okay...so thumping the dashboard didn't help.
Has anyone replaced these things before?
EDIT: since you said you still have 2 speeds on your motor that work, this method probably wouldn't be very effective.
