Transmission Light on after sea foam...
Old Jun 24, 2006 | 09:16 PM
Dorian7's Avatar
Dorian7
Default Transmission Light on after sea foam...
so i used sea foam by pouring it through the throttle body, I waited untill the car died and then I waited 5 min and started it again, when I did the transmission check light was on, any ideas?
Old Jun 24, 2006 | 09:38 PM
dubcac's Avatar
dubcac
I
I don't think your car has a transmission check light. It's a check engine light. Check the FAQ on how to check the code.
Old Jun 24, 2006 | 10:44 PM
Dorian7's Avatar
Dorian7
I think you might be right my bad, sorry about that this is all pretty new to me still. Ok well I guess I will search and try to find stuff out...
Old Jun 25, 2006 | 02:38 AM
Kai's Avatar
Kai
Rotorphile.
If the car died while running the sea foam, reset the computer and start it up again. If it still shows an error, you'll need to go into more detail.
Old Jun 25, 2006 | 09:04 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I cannot immagine pouring liqued or foam into my throttle body. Am I understanding that correctly? It just does not seem right...but I have never used seafoam either.
Old Jun 25, 2006 | 09:14 AM
carta79's Avatar
carta79
Life after death
Yeah check the code; it could be a fouled o2 sensor or spark plug.
Some people suck it up through the throttle body; some through a vacuum line. I don't know why people started using that crap on their Hondas/Acuras anyways. If you use an additive on a car and the car throws a check engine light afterwards, how's that any good. Don’t our manuals specifically state not to use additives?
Old Jun 25, 2006 | 01:18 PM
Dorian7's Avatar
Dorian7
OK how do you reset the computer?
Old Jun 25, 2006 | 02:04 PM
dubcac's Avatar
dubcac
I
Go to the engine bay fuse box and pull the 7.5A backup fuse. Let it sit for 30-60 seconds and pop it back in. Start the car and don't touch the gas.
Old Jun 25, 2006 | 03:30 PM
carta79's Avatar
carta79
Life after death
Did you even find out what the check engine light is?
Old Jun 25, 2006 | 04:11 PM
Dorian7's Avatar
Dorian7
the light comes on every time you do (from waht I have heard) and so it is because you pour it in untill it dies, and then car thinks that there is a problem with the motor, so yeah but if there were somthing actually wrong the light will come back on after you reset it.
