Type R Trans
Old May 26, 2006 | 04:45 AM
Shooting411's's Avatar
Shooting411's
aka Gorilla Unit 33
Default Type R Trans
Yo guys. I was wondering if you might be able to help me out im trying to find the gear oil fill hole on my type-r tranny. i think it may need to be filled again and i wanna make sure im putting the fluid in the right hole before filling it. i looked in the maintence forum but couldnt find it. any help would be appreciated... (pics make it better)
Old May 26, 2006 | 06:38 AM
shivers's Avatar
shivers
Moderator Alumni
There should be two bolts near each other on the side of the tranny closest to the passenger side front wheel. One should have a square cut-out for a 3/8" drive rachet extension and the other should be a 17 or 19mm (don't quote me on size since I haven't worked on a B series in a while). The lower bolt is the drain and the upper is the fill.
2005 s2000
Old May 26, 2006 | 06:53 AM
Shooting411's
aka Gorilla Unit 33
i see the 3/8's drive square cut one... but is that the fill hole? and also how should i go about filling it? like do i have to take the wheel off and all?
Old May 26, 2006 | 08:17 AM
teg92's Avatar
teg92
WHAT OK YEAH!
heres a write up on it from c-speedracing. All u need is a 3/8 rachet and a 17mm wrench or socket and a funnel with a tube on it
http://www.c-speedracing.com/howto/t...transfluid.php
Old May 26, 2006 | 11:49 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I just put a hose on the pipe coming out of the top with the rubber cap on it and tape a funnel to the hose and pour the fluid in. I don't have to get underneath the car and it won't require a pump to get it in.
Old Jun 2, 2006 | 08:01 PM
bbasso's Avatar
bbasso
Look here: http://www.c-speedracing.com/howto/t...transfluid.php
Opps some one beat me to it :P
Old Jun 7, 2006 | 05:21 PM
Shooting411's
aka Gorilla Unit 33
thanx guys i appreciate the help... although changing the trans fluid didnt help what i thought it would... after searching the forums and others i couldnt find a cause for a humming noise im hearing from low rpms in any gear... ohh well if anyone has any idea please pm me and well talk
