2nd Gen Mounts
Old May 26, 2006 | 06:19 PM
fliptout's Avatar
fliptout
Default 2nd Gen Mounts
I can't find any good Engine mounts for my integra. All that I can find are inserts. Does anyone have any info?
Old May 26, 2006 | 09:29 PM
quikflip27's Avatar
quikflip27
did you try hasport.com?
quikflip
Old May 27, 2006 | 08:09 AM
JETSPD1477's Avatar
JETSPD1477
O RLY?
go factory... poly mounts in a DA vibrate pretty bad.
Old May 27, 2006 | 08:47 AM
g290ls's Avatar
g290ls
they call me tater salad
i would go with new factory mounts with new bushings, hold the stress a lil bit better but thats my .02 cents
Old May 27, 2006 | 09:07 AM
92g2b18c1's Avatar
92g2b18c1
well, to tell u the truth, i got a DA integra with a b18c1 in it and it vibrates everything, i wont lie, but if ur planning on getting upgraded mounts then quite frankly you can expect that, im very picky and all the vibration doesnt bother me i just find ways to stop it...by the way, i got my mounts off of www.passwordjdm.com go under the link that says...engineparts/swaps...and then go under engine mount kit and you can find them there...cheap too
Old May 28, 2006 | 07:38 AM
fliptout's Avatar
fliptout
Thanks for the link 92g2b18c1 That's Exactly what I was looking for.
Old May 28, 2006 | 02:06 PM
quikflip27's Avatar
quikflip27
jw, what do you use to stop them vibrations, i installed 3pc. hasport mounts and my car is louder inside then out. i tighened all the screws alittle more and that worked for a little, but now their back again. got any suggestions?
quikflip
Old May 29, 2006 | 09:16 AM
myjdmda's Avatar
myjdmda
Default 2nd Gen mounts
www.innovativemounts.com These guys make factory replacement kits,I have them in my street car, and I like them better,then the ES poly bushing inserts,priced lower then HASPORT,and about the same quality,their a good buy IMO.
P.S. If your getting lots of vibration from ES poly bushing inserts, then you probably, have a broken or rip mount already!! inserts work well with good mounts, so if your mounts are bad, it defeats the purpose of having inserts in them.
Old May 30, 2006 | 07:43 AM
92g2b18c1's Avatar
92g2b18c1
anything you can find that you can stuff in a place where its vibrating that you cant see the peice that u stufffed there, thats what i did, ur never really goign to b able to stop ALL the rattling so do what ya can and get used to the rest...oh yea, and i have the middle grade mounts..theres 3 different stiffnesses...theres a fair amount of vibrating for the black mounts idk about the others...
Old May 31, 2006 | 06:17 PM
quikflip27's Avatar
quikflip27
ok, thx for the help so far. my mounts are solid hasports that i put in with my swap. i dont know their stiffness n i got em for 300. it causes everything from the dash to the rear brake light to vibrate/rattle.
quikflip
