- Help me buy civic hatchback 92>95
- swap info wanted
- I need Tech Help AsAp Bseries Questions ** NEEED HELP FAST** THanks
- function form coilovers
- How to install A/C in 96 civic?
- SOHC non-vtec to DOHC vtec common wiring problems
- Clutch Questions?!?!?
- 06 and xm
- paint over fading cf hood?
- H22a + turbo?
- Before I buy
- I've got a head scratcher question?
- Is this car worth $7600? new driver pls help
- PS belt slippage, noise on passenger side.
- Bent Valves! What else should I do..?
- What's the best place online to get a complete b16 swap.
- OEM ITR axleback.
- idle is still funny
- input shaft bearing
- Replaced timing belt - head gasket blew, now pinging
- new engine smoking
- h22 help me
- Look what I found!
- lol sunroof problems
- the Cheapest Motor site
- Please help me!!!!
- Where do these plugs go, please look!
- i have 2 used 92-95 civic distributors dirt cheep!
- which ecu
- 5th Gen center console replacement
- 2003 Honda Civic EX boosted?
- Civic coupe horse power ?
- speedometer not working help...
- Tach
- Riced out? and rattling doors
- Head Unit Installation Question
- Drag Rims
- cluth question
- Installing a Short Ram Intake
- del Sol trimlines
- Water in the floor - Driver's side
- H1 hid into 98 ex. will it work?
- 1996 Civic Dx Coupe back glass
- 98 Si "Funny" sound
- Do EG sedan front quarter panels fit on EG hatches?
- 17 x 7.5 on 6th Gen Civic
- A/C tax
- Who's Running LSD on their car in here?
- 89 civic dx exhaust problem
- Reprogram to get better MPG?
- Clunking/Clicking noise - Not wheel bearing or CV boot!
- Autometer Question
- would a td04 turbo kit off a dsm fit a del sol
- brake lights dont work after alarm install....
- Vtec hesitation
- Least expensive OEM springs?
- mini me vtec wiring question with pics
- what's the best repair manual?
- passenger side window..
- what type of engine.
- Newb here!!
- srs light!!!
- Transmission chunks
- need help before i buy stuff for my motor
- turbo throttle body
- Ls swap problem
- 90-93 integra rear trailing arms (rear disc conversion) fit on 96 honda civic 4door?
- Civic Pricing Question
- Misfire or popcorn popping sound between 2-2,500 RPM
- 01-on D17 stage 1 camshaft on D16????
- Sparco Super Mesh Repica???
- exhaust-ing
- DIY: LED Gauge Cluster
- Need some help please
- under drive kit
- 2001 Civic Cluster Gauge (odometer screwed)
- headers \ exhaust piping
- How to check or reset SRS light on 01-03 civic?
- Antifreeze leaking around the water pump area
- OBD2-1 conversion on a D16Y8 Auto
- is there a way to wire my headlights...
- Auto tranny probs 98 civic
- A recent Honda meet in Dublin Ireland
- auto tranny question
- Anyone that has the
- Del Sol Side Skirts
- i have a code on my 97 civic cx 15 ign. signal output
- Alteeza Tail Lights -- Instructions?
- Axle
- Sad to say goodbye
- integra GSR vs ek coupe
- Lacking Power
- Help Fixing Rust On Back Corner Panels
- o2 sensor prob
- o2 sensor prob
- new engine harness!
- Code 9 TDC Sensor
- obd2 - obd1
- wich is best stock manifold for my D
- What kit?
- JunkYards in NE pa
- HELP!!! my passenger seat
- A few questions about an Engine Swap
- Tire Questions
- a little help please and thank you
- 94 EG Hatch with 97 F22 Accord Drivetrain questions
- fuse diagram
- Clutch bearing going?
- Stoopid clutch question
- ya
- Ever done this?
- Gauge Cluster
- honda civic radiator
- what do i do when head gasket is leaking
- car makes a whistling sound after i turn it off...
- Getting My Car Ready For Spring/Summer
- Help 93 Honda Civic collision
- Custom turbo plans. some help?
- Transmission Conversion
- 2004 Civic EX Header question
- Car not Starting, Need Expert Help!!!
- Help Please removing an VAFC
- bad throttle response
- 1.7L Vtec motor
- 91 Si seats into a 97 civic?
- i NeED 93 - 95 eX CiviC SheLL!!!
- '01 headrests on a '00 civic?
- coilover help
- reverse gear grinding
- del sol seat covers?
- Car using clutch fluid
- Spark Plug Wires
- fuel guage JDM cluster EG6?
- Ek civic suspension?
- e.g.. ash tray bulb?
- For B18C1 & 92-95 Civic owners
- 2001 Civic: key light blinking
- Will This exhaust manifold fit?
- Quick V-AFC Question
- confused about intakes
- Brakes drop to the floor
- help with tuning my 2000 civic si
- Bogging, Misfire, Odd Idle and ECU Code 43
- temp gauge
- My Alessio wheels 15"
- New Belt Squeals
- installing a new clutch on a 1994 honda civic with a 2000 acura ls motor
- Valve Upgrade question
- HELP: i think i blew some fuse for my dome light
- ECU and chipping question.
- So I went to Pep Boys!!!!
- Del SOl Alarm stopped working!!
- 1995 Civic HELP PLEASE
- Running on 3 cylinders
- vtec system malfunction
- Cargo mats for 98 civic
- Best ECU
- 96 ex hose locatations HELP!!!!
- Installed 255lph fuel pump now my car is in limp mode
- Intake Showdown
- 99-00 Si 15" oem factory wheels - hub centric acorns?
- wheels 15"
- Crimping fuel pump wires.
- Have HX with CVT tranny, want to swap for regular auto tranny. Will this work?
- 96 cx HB, how do I get speakers to work for the rear?
- To Mr. Crazy Cone Chaser...
- Tech advice please
- Identify that Body Kit
- Need Horsepower
- Wiring Help
- Car runs without key... after catching on fire?
- Help with Rear lower control arms
- Energy Suspension Shifter Bushings for Acura/Honda
- how to install m3 mirror on a honda civic 98
- How to take rear seat out of a 95 sedan?
- Walbro 255
- Short Ram intake
- Fake S-Tech Teins on ebay???
- tranny mount?
- z6 dizzy vs d7 dizzy
- HELP: finding a wire
- HMMM...I need an opinion
- slight jerk when car shifts into 2nd gear
- Civic Type R Front Lip Install
- Can someone run a Carfat VIN report for me?
- battery is dieing on me
- Civic Parts Removal HELP NEEDED
- Civic Trim Question
- How the hell can these be related??
- Stealthbox?
- eg windshield wiper squirter info
- radiator fan never cutting on...
- Anyone with any
- Car's coolant temp.
- dc or greddy
- Change front blinker light bulb - Honda Civic 1998
- need part number
- Really wierd Start Problem
- need help
- Pace Setter Exhaust System
- SHOCKing question
- Losing ALOT of power when...
- Engine is burning slight Oil
- Fan issues -_- wtf
- Ctruch or tranmission? Which one i need new?
- fuel problem?
- Civic Noise
- losing power, not running as smooth...
- CEL gone,still got a problem(knock on wood)
- yokohama A520's
- Radiator Giving Out, Going with Aftermarket
- front bumper
- k20 swap cost
- where can i get a new hood latch for my del sol
- slotted or drilled rotors? where to buy?
- 2005 Civic Coupe Upgrade Question
- Will This Fit My Engine?
- 3in or 2.5in
- injector question
- Vx head on Dx block
- broken bushing bolt
- 96-00 civic greddy kit on 92-45 civic???
- How to make my tail lights darker?
- need information!!!!!!!!!
- RE:99-00 Si owners??
- Car Running Rich, How to fix?
- Na B18c
- Which brake pads ?
- No power whatsoever...
- psi
- wideband 02 sensors reading
- Problem with brakes. Racine WI. 92 Hatch.
- GSR leathers
- is this possible
- coilovers
- I vtec
- Broken mount from d16z to d15b vtec
- 92 civic hatch with type r
- Tony's 2006 Build
- So I'm chipping my ECU and my 373 chip is too big.
- how to install side mirror signal lights
- how do wastegates work
- Head Gasket is going in 93 Civic EX Coupe...
- Info on eg JDM cluster?
- help with eg cluster
- Cat back system & SMOG Test
- 92 honda civic vx driveability need help
- building a turbo
- street/strip tires for civic bf goodrich
- high fuel pressure
