Radiator Upgrade question
Old May 18, 2006 | 09:19 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Default Radiator Upgrade question
Since it's becomming summer and my car's engine runs hot. I was wondering if a radiator really cools off the engine bay. I'd like to reduce heat soak as summer is approaching for the extra summer driving, so just wondering if a Fluidyne or any other performance radiator would make a noticeable difference or should I just get a tranny cooler and call it a day?
I'm only asking since my car runs better when cool.
Old May 18, 2006 | 10:48 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Have you tried changing your thermastat, Flushing your radiator? How do you put a trans cooler on a civic?
Old May 18, 2006 | 12:14 PM
raiden571's Avatar
raiden571
turning u inside out
ebay radiators work fine. and get a slim fan for like 50 bux and a fresh thermo from th eparts store. flush ur radiator, refill 50/50, use a bottle of water wetter and ull be ready to rock
Old May 18, 2006 | 03:58 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
I have a fluidyne radiator. I love it.
Old May 18, 2006 | 09:15 PM
InfiniteVTec
The Dealer
I have a 160 degrees thermostat and running water and Redline water wetter, but I know if I run it hard for around 2-3 hours doing sprints and drag racing I find myself having to add about a 1/2 a quart oil and also the coolant level on the overflow decreases some. there's a slight kink in the coolant tube going into the IM.
I notice my car runs pretty well cold on a startup below normal operating temperatures. It makes me wonder if this could have anything to do with valve clearances.
Old May 18, 2006 | 09:21 PM
InfiniteVTec
The Dealer
The tranny fluid cooler is part of the lower radiator on automatics. I intend to swap in a Fluidyne Radiator which doesn't combine the tranny fluid cooler and adding a B&M tranny cooler in the front of the structural beam right behind the front bumper so it don't block the air path to the radiator.
does this sound like the right thing to do? or should I just say fuq it and throw a test pipe on my ride, which would remove the O2 sensor and throw the car into Open Loop which would be like startup, and just tune the fuel to compensate using wideband? would that work better than close loop tuned on a obd2 car?
Old May 18, 2006 | 09:39 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You don't need a new radiator on a stock motor.
I am running my OEM radiator (149k miles on it) with a set of slim pusher fans and a 70/30 water/coolant mix with water wetter and my ECT is under 200* F in hot weather.
Old May 18, 2006 | 09:47 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
I didnt know you were runninga auto trans. That clears it up. thanks.
Old May 18, 2006 | 09:51 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
test
InfiniteVTec
The Dealer
okay... how about a tranny fluid cooler since i got an auto... n what about close or open loop tuning which one? 0_o
